Old 01-19-2008, 10:57 AM   #1
ucmydust68
fuel
how do you know what angle to put your....
how do you know what angles to set up your suspension. say if i use c4 or c5 suspension? is there a book that gives you the angle it should be at? im looking to build something from scratch and i will admit im a painter, i love building engines, but i paint every day and i dont have the suspension knowledge. and also about how much in materials is this scratch build frame usually costing everyone??
thanks
chris
72 w/67 front clip
415ci
fuel injection
t56
air ride
18/20's
ucmydust68 is offline   Reply With Quote
Old 01-19-2008, 12:44 PM   #2
FnLow69
FnLow69's Avatar
Re: how do you know what angle to put your....
well my frame steel is under $200, but im using a dropmember from porterbuilt. The frame is cheap, its everything else thats going to add up quick (like 4 link, bags or coilovers, tubular arms, ect ect.).
FnLow69 is offline   Reply With Quote
Old 01-19-2008, 01:55 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
The way I started to learn about chassis and suspension was by reading all the books I could fine. I whipped out the VISA and made amazon.com a lot of money! Once I understood the basics and fundamentals I moved from books to software (more money).
Many people just take the factory specs or build a jig off the factory crossmember and then utilize those specs for a retro-fit. Once you really start getting into the geometry and design portion of suspension you'll want some software to tweak the design and make some changes to better suit your wheel-base, trac-width, center of gravity, etc. The software will allow you to make changes and see their effects without any fabrication.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-19-2008, 10:37 PM   #4
ucmydust68
fuel
what software do you recommend?
72 w/67 front clip
415ci
fuel injection
t56
air ride
18/20's
