Old 01-19-2008, 11:16 AM   #1
kenm78
Broken Down
kenm78's Avatar
headlight adjustment
Ok I thought I adjusted my headlights but I guess by the number of people flashing me I didn't who here can explain to me the proper way to adjust my headlights ?????
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 01-19-2008, 12:09 PM   #2
72BLUZ
72BLUZ's Avatar
Re: headlight adjustment
the best way i found was just to get on level ground in the dark. turn the lights on. use another vehical for an example. preferrably one that is fairly new. i used my 92 to help get mine right.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 01-19-2008, 12:26 PM   #3
kenm78
Broken Down
kenm78's Avatar
Well my wifes Ford sits higher than my old reliable but thats not a bad idea!!
kenm78
1982 Chevy 4X4
Project truck
Old 01-19-2008, 12:29 PM   #4
72BLUZ
72BLUZ's Avatar
it may sit higher, but it will give you the idea of how they should be set. i failed to mention you should cover up one light at a time on each vehical to get the angle right.
Old 01-19-2008, 12:49 PM   #5
kenm78
Broken Down
kenm78's Avatar
How about if I park the known good truck about 15-20 feet away from the wall and put tape side to side to indicate height and the tape up and down on each side to indicated location of light?? think that might work.
kenm78
1982 Chevy 4X4
Project truck
Old 01-19-2008, 02:20 PM   #6
matthufham
i used my garage door, it has lines going across, and parked in the middle i let the sides meet the edge of the garage and set the height at a good position for driving. test the high beams too, those are more focused
matthufham is offline   Reply With Quote
Old 01-19-2008, 02:55 PM   #7
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
I do the same thing. I back it into the garage, looking at the door, then line em up. Then I drive it out and check it.
Pl4yboy is offline   Reply With Quote
Old 01-19-2008, 03:41 PM   #8
Premium72
Premium72's Avatar
just park the beast flip on the lights and adjust the way you want them. by the time those other cars pass you, theyll have gotten over your lights. ehh. i always drive with my highbeams on (xenons) just for safety, too many deer in my neck of the woods no to. ive been there done that...
Premium72 is offline   Reply With Quote
Old 01-19-2008, 11:14 PM   #9
68gmsee
Active Member
68gmsee's Avatar
I disagree. That's being discourteous to other drivers who may have trouble with bright lights and it can cause an accident just so you can be "safe".
I can attest to that because I drive country roads at night here in Texas and sometimes have to pull off to the side (no shoulders) by someone that doesn't care how their lights and "fog" lamps are adjusted.
I personally know of one fellow here that followed a truck driver that almost blinded him. The driver of the truck had to call the sheriff.
68gmsee is offline   Reply With Quote
Old 01-19-2008, 11:17 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Also forgot to add, here in Texas there's no requirement by inspection stations to check you beam adjustment. It's up to the local cops, DPS, etc.
You can and will get ticketed.
Old 01-20-2008, 01:49 AM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Another "old school" method of setting is to park 25-ft away from a wall, with the vehicle level. With the headlights on low, you should be looking at a bright spot 24-inches above the floor. Supposed to be a pretty good adjustment if that is what you have.
Here in Arkansas, there are no stations doing vehicle inspections, and a headlight aimer is scare as hens teeth. To top that off, the dealerships don't do it on the new vehicles, either, as far as I can tell. They don't have to.
Member Nr. 2770
Old 01-20-2008, 01:57 AM   #12
Premium72
Premium72's Avatar
ehh. the way people drive around here. they dont need my high beams as an excuse to plow them selves into an oak. but i hear ya.
Old 01-20-2008, 02:56 AM   #13
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
That sounds about how I was taught to do it.
But I was taught that you drive the truck almost right up to the wall, mark the height of the beam on the wall with some tape, and then back the truck up 20-25 ft.
Then you aim the headlights to be level or below those tape marks. ( i guess below if you are driving in a lifted vehicle).
It is really important that you do it on level ground though.
This is supposed to work for any vehicle at any ride height.
I think the 24" height is around right for a stock 2wd truck of our era. That height might be different on a 4x4 or other vehicle.
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 01-20-2008, 07:26 AM   #14
kenm78
Broken Down
kenm78's Avatar
Thanks for all your inputs I will adjust it when it gets dark tonight. Thanks again.
kenm78
1982 Chevy 4X4
Project truck
