Old 01-19-2008, 11:34 AM   #1
67L30WGN
67L30WGN's Avatar
Fusible Link & Fuse Question
I'm sorting out my new truck. Next on the list is to square away a few wires. The fusible link from the positive battery cable to the junction block on the fender is missing. There is also a missing fuse from the in-line holder in the black wire (see attached link) that runs from the same junction block into the bundle along the front of the radiator. I'm not yet sure of its function. My question is, 1) what size is the fusible link from the battery to the junction block and 2) the size & type is the missing fuse in the black wire?
http://picasaweb.google.com/westsail...37467706485410
1972 Cheyenne Super 10 LWB
1965 Nova SS Evening Orchid
1967 Nova Wagon Factory Disc (1 of 565), 327/PG
1964 Ford Fairlane 500 HT
1962 Nash Metropolitan Convertible (Wife's car)
67L30WGN is offline   Reply With Quote
Old 01-19-2008, 12:07 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Fusible Link & Fuse Question
The missing fuse sounds like the short 4amp fuse that is part of the ammeter circuit. If it is there is another one on the driver's side beside the radiator.
I am not sure about the size of the fuseabel link, but I am sure some one else will know.
Danny - Southeast Missouri
Shyguy is offline   Reply With Quote
Old 01-19-2008, 12:15 PM   #3
67L30WGN
67L30WGN's Avatar
That sounds right. The space inside the fuse holder is short.
Old 01-19-2008, 10:19 PM   #4
Luvlegs
Luvlegs's Avatar
I'll go outside and look at the fusible link wire I bought (can't remember the size) - local part store, came in a small roll, cut TWO lengths like the originals (there were two) - soldered 'em in.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-20-2008, 03:02 AM   #5
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
good question about that fuse/ and fuse link. Both were burned out in my truck, and I did manage to drive it like that for about 5 years... I still don't know what it coulda done!
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 01-20-2008, 03:19 AM   #6
chevy72blu
chevy72blu's Avatar
I scratched my head for a about 4 hours when mine blew out and I had zero power (had to tow it home from the track). No ignition, no radio, nothing. I replaced mine with 12 AWG (maybe 10) from the parts store. And as for that black fuse holder... Mine didnt have one.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 01-20-2008, 03:45 AM   #7
Shyguy
Junior Member
Shyguy's Avatar
The two 4 amp fuses only affect the operation of the ammeter.
The ones on my 72 GMC were blown when I got it and I never replaced them during the 15 years I owned it, since I like a volt-meter better.
Danny-Southeast Missouri
Old 01-20-2008, 04:02 PM   #8
67L30WGN
67L30WGN's Avatar
I checked the fuse on the opposite side (thanks for the tip) and found it was an AGA 10 amp, so that's what I purchased and placed in the empty side. Perhaps the po was popping the 4 amp fuses? Tomorrow, I'll see if my ammeter acts any different.
Without the fuse, the truck seemed to run just fine. I'm straightening out the wiring because at idle the ammeter shows discharge and the headlights dim. It may prove to be the voltage regulator and/or alternator, but I wanted to rule out the black wire since it ties in at the same junction as where the voltage regulator takes its reading (I think).
If anyone know, I'd still like to know what size the fusibible link is suppose to be off the bat (+).
Old 01-20-2008, 05:56 PM   #9
GMC Jim
GMC Jim's Avatar
definition of a fusible link... is a short length of solid wire that is 4 gauges smaller than the wire size to protect...to protect a 12 gauge wire, insert a short length of 16 gauge.....
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
