Old 01-19-2008, 01:14 PM   #1
1980GMC
1980GMC's Avatar
Swapping to 73-78 front grill?
I previously thought about swapping my front clip to a 83-87 front end, but have found a new love for the earlier front clips. I like my 80 front end, but nothing beats the beauty of those round headlights.
Do all the 73-78 moldings and bezels fit onto my rad support? and what are all the parts I would need?
Thanks,
Wes
Wes
1980 GMC Sierra SCSB-2WD
1986 Chevrolet C10 SCSB-2WD
1980GMC is offline   Reply With Quote
Old 01-19-2008, 01:25 PM   #2
chevymotocross
chevymotocross's Avatar
Re: Swapping to 73-78 front grill?
Not sure on your question but I will say you are making the right choice. I have an 87, and love the 80's front clips but If I had a 73-80 I would DEFINETLY not swap it to 81+. The round lights were the first half of this generation truck, I would never want to "molest" it. The round lights always had a spot in my heart lol.
chevymotocross is offline   Reply With Quote
Old 01-19-2008, 01:29 PM   #3
andresco50
andresco50's Avatar
Are you sure I love the rectangle headlights of my 80!!!! the grill too
andresco50 is offline   Reply With Quote
Old 01-19-2008, 02:09 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Keep in mind there were two styles for 80. The Silverado got the single rectangle headlight, and the lower trim level got the round one.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-19-2008, 05:00 PM   #5
xtreme80
Wishin' I had more money!
xtreme80's Avatar
My Scottsdale has the round ones.
As far as I know, you need new headlight buckets and lights. Maybe someone else can chime in but you might need a new grille, grille trim, and other little parts as well.
xtreme80 is offline   Reply With Quote
Old 01-19-2008, 11:58 PM   #6
1980GMC
1980GMC's Avatar
My truck has the rectangle ones, and its a Sierra Grande. Is that the same trim level as the Silverado?
Buckets + Lights alrighty then.
What about the grille moldings?
Wes
Old 01-20-2008, 12:36 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes that is the GMC version of Silverado.
You might trying looking on LMC's website. I don't always recommend them for parts, but they have the greatest exploded views and parts lists available.
Articles-
"Refining Sierra"
Old 01-20-2008, 01:16 AM   #8
K30_dump
Hello,
I have personally always thought that the 73-80 Chevy trucks were the coolest design in the history of these trucks. Do you plan to swap the grille itself, or just to the round headlamps? If you do swap the grille and decide to go with a 77-80 grille, it should swap right in. The 73-76 grille requires the removal of a few vertical supports to fit into the radiator support. LMC shows the same P/N for the core support from 73 up to 80 (I know all of this already because I plan to install a 73-75 grille into my K30 project (using a '79 support) . The early grille is deeper and will not fit with the vertical members in place (luckily, as easy as everything else on these trucks is to work with, they are only bolted to the core support). As far as swapping only to the round headlamps (reusing the same grille), you should only need the headlight buckets and chrome bezels. Long story short, you can make your truck look exactly like any style from 73 up to 80 using the same radiator support. Good luck in your swap.
Joe
K30_dump is offline   Reply With Quote
Old 01-20-2008, 01:45 AM   #9
bigblock73
yeller
bigblock73's Avatar
Are the lower valances the same, where the front signals reside? I thought they were different too.
bigblock73 is offline   Reply With Quote
Old 01-20-2008, 01:59 AM   #10
K30_dump
Jeff,
I believe you're correct. I forgot to mention that in my previous post. Luckily, that's just a bolt-on panel as well. So as it stands, Wes would need the headlamp buckets, bezels, turn signal assemblies and lower valance panel to do this right.
Thanks for the correction,
Joe
Old 01-20-2008, 02:56 AM   #11
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Difference is the Lower valence, headlight bezels, buckets and lower grill trim (79/80 YE9 got the full chrome piece)
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-20-2008, 06:33 AM   #12
1980GMC
1980GMC's Avatar
Originally Posted by K30_dump View Post
Hello,
Joe
Thanks for the info Joe. Ill take a look at my rad support and take off those vertical members.
Thanks to everyone for all the great help.
Wes
Wes
