Old 01-19-2008, 06:03 PM   #1
SLVESSELS
69 6lug swap
Can some one tell me excatly what i need to swap my drums for 6lug disc.what year spendles can i use and rotor and do i need to change ball joins ant tie rod ends
SLVESSELS is offline   Reply With Quote
Old 01-20-2008, 01:55 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 69 6lug swap
Contact Early Classic Enterprises, McGaughey's, etc., for their kits....look on-line and you'll see what comes in the kit. You can get these kits in 5 or 6-lug style.
Some aftermarket kits use the original tie rod ends, some don't. That's supposed to be a selling point.
When using used components, 1971-72 trucks will have all the right stuff if you find one that is worthy of getting parts off of, but they're 5-lug. There are those who will tell you that you can swap in a cross-member from the front of 1973-87's (I think I'm right) and also have later model 5-lug stuff. I don't know if any of the 88-up crossmembers are swappable onto these frames, or not. Never saw any posts or heard anyone ask.
Member Nr. 2770
Old 01-20-2008, 09:15 AM   #3
corn
Re: 69 6lug swap
Here's how I remember ...
88-up 1/2 ton spindles
88-up tie rod ends
88-up 3/4 ton 2wd rotors
'68 3/4 2wd lower control arms
stock upper ball joints
88-up lower ball joints.
corn is offline   Reply With Quote
Old 01-20-2008, 10:09 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 69 6lug swap
Are those 88-up 3/4-ton 2WD rotors 6-lug?? I seem to remember seeing 6-lug wheels on my brother-in-laws 88 or 89 Chevy 2500.
This is good info. Thanks!
Member Nr. 2770
Old 01-20-2008, 10:24 AM   #5
corn
Re: 69 6lug swap
Yep. Half ton 2wd (5 bolt with 1 1/4 rotors) have the same spindle length as 2wd 3/4 (6 bolt).
Old 01-20-2008, 01:15 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: 69 6lug swap
The 6 lug 3/4 tons are the lighter GVWR, so be aware that not all 88 - up's have 6 lug rotors. A lot of them have 8 lug rotors. I only mention this so no one buys anything from a 88 - up 3/4 ton truck sight-unseen!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 01-20-2008, 01:18 PM   #7
67_C-30
67_C-30's Avatar
Re: 69 6lug swap
I looked it up, and the 7200# GVWR trucks have 6 lug and the 8600# GVWR trucks have 8 lugs. You will need to specify when buying new.
My trucks
