Old 01-19-2008, 09:30 PM   #1
azsmokey
Custom subwoofer enclosure
Who has replaced their old interior gas tank with a sub enclosure. I am contemplating building a box for our 72 as part of the restoration. I would like to get some ideas and see what other owners have done.
azsmokey is offline   Reply With Quote
Old 01-19-2008, 11:25 PM   #2
70short
Re: Custom subwoofer enclosure
3-10"s
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 01-20-2008, 12:12 AM   #3
Andy4639
Old member
Andy4639's Avatar
Here is mine installed.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-20-2008, 12:53 AM   #4
nvrsatisfied
nvrsatisfied's Avatar
no pics yet (waiting to get done with the entire build). but look into "shallow mount" subs. i am doing 4 of our KICKER CVT 10" subs in my cab. they are only 4" deep and ask for .39 cu ft- .8 cuft per sub. this way i am not biteing the steering wheel.....good luck lets see the pics when you get done.
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations)
Perry, Ok.
We're just two guys, trying our best.
72 cheyenne super
https://67-72chevytrucks.com/vboard/...d.php?t=811512
55 chevy truck
http://67-72chevytrucks.com/vboard/s...d.php?t=840174
nvrsatisfied is offline   Reply With Quote
Old 01-20-2008, 01:24 PM   #5
azsmokey
Thanks for the info. I'll check into the shallow mount subs and start my measurements for the enclosure. I will incorporate the center console into the rear panel as well for a more fluid look.
Old 01-20-2008, 02:37 PM   #6
jugernot
Life, Be In It.....
jugernot's Avatar
There are some pics that I save from other threads.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 01-20-2008, 03:08 PM   #7
AuggieStyle
AuggieStyle's Avatar
will they fit under the seats? thought of making a custom bottom for my center console to mount one inside sort of like the new subs on the GM suvs.
AuggieStyle is offline   Reply With Quote
Old 01-21-2008, 02:38 AM   #8
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
I'm likin the boxes on here, good for ideas lol, my buddy and I are going to build a fiberglass box to hold two Kicker 12's and an alpine amp. Should be good [=
ProStreet68SB is offline   Reply With Quote
Old 01-21-2008, 01:01 PM   #9
Psycho71
Psycho71's Avatar
Here's mine. Started building it today. Tomorrow I'm gonna start on the console. Which will tie into the box.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-21-2008, 01:11 PM   #10
bowtieboy93
bowtieboy93's Avatar
i was thinking in the last couple of days of doing a factory gas tank in fibreglass and using the original tank carpet so it looks like the tank, but its really just a box?
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 01-22-2008, 01:35 AM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That would be a cool idea.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-22-2008, 03:07 AM   #12
fastom
That's right, it's Copper!!
fastom's Avatar
I haven't finished mine but I have started.
fastom is offline   Reply With Quote
Old 01-23-2008, 12:00 AM   #13
nvrsatisfied
[QUOTE=AuggieStyle;2537924]will they fit under the seats? thought of making a custom bottom for my center console to mount one inside sort of like the new subs on the GM suvs.[/QUOTE
depends on the amount of air space you have, look at the specs of shallow mount you are interested in and kinda go from there.
Perry, Ok.
72 cheyenne super
55 chevy truck
