Can a 73-78 clip be put on an 81-87 truck?
Gentlemen,
I'm enamored with the looks of the early boxy front end, but really desire the performance/reliability of an '87 truck with fuel injection and overdrive. Seems like it would be easier and cheaper to swap the front clip than retrofit the drivetrain. Is it as easy as I think? Thanks, Ed |
Re: Can a 73-78 clip be put on an 81-87 truck?
I put a 87 front end on a 79 and in my opinion it would be less work to go the otherway
It'd be alot cooler if you did
It would be easier than going the other way... I don't see why it wouldn't work. Just make sure you swap the bumpers too to make the look complete.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Yes, you can go that way and it won't require as much change, but you will have to swap to the shorter 73-80 style wipers to clear the hood and change the wiring connectors to match the new headlight setup, AND make a bracket to allow you to put the 73-80 bumper on the frontend as the frame horn ends are different.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Happy to be here
![]() Join Date: Mar 2000
Well yes, and no. Or maybe I should say that depends. If your going with a 73-78 clip most of the big parts can be had at a fair price, but they aren't cheap "or" abundant any more.
Lets start with the fenders. Even in a dry climate like Texas, finding rust free fenders is hard to do. The passenger side is going to have rust at the rear from the a/c drain, and rust at the front from battery run off. The drivers side is easier to come by. If you decide to skip the hassle of tracking down rust free fenders then you can go with aftermarket metal. There is only one choice for fenders if you want quality. Goodmark makes a fender that is as good as OEM or better. Everything else is junk...period. If you want a cowl hood, no problem. Goodmark will supply that too. If you don't want a cowl hood...uh....your screwed. Trying to find a clean, rust free oem hood that isn't cracked is close to impossible unless you want to pay a fortune for the rare NOS version that hit eBay. OK so somehow you have found fenders, hood and a rust free core support. So far you only spent a grand if you include shipping. Now your going to need the trim. For headlight bezels you have two choices. The cheap plastic ones for 9.95 or NOS units. The NOS versions are averaging 100.00+ on eBay these days when you can find them. It's not uncommon for them to hit 130.00. You can buy repoduction grills for 75-78 but not for 73-74. LMC makes a pretty cool plastic "Billet Look" grill that might suit your taste. Can it be done? Absoulety! Is it going to be cheap than swapping motors? Not unless you are lucky enough to find a donor truck that you can buy it all at once. Will it look *****en? Priceless... ![]()
Right in front of you.
That's a badass pic N2TRUX!
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
Happy to be here
Yes it is, isn't it?
Another view...metal:
Not to steal a thread but my brotherinlaw wants to change from a 74 to a 85. How hard is this?
The fleet 94 Chevy 4x4 reg cab 2018 Traverse (wifes car) 1977 SWB stepside 1949 Chevy truck |
I bought the 73-78 LMC plastic bezels and they didn't fit. Couldn't get them to sit flush so I could screw them on. The original metal ones on the truck fit fine.
Anyone else have problems with them ? |
Wishin' I had more money!
N2TRUX, Is the air-dam off a 81-87 truck and you just fitted it to it, or is it off something else?
#12 | |
Takes a bit of cutting to get a later clip on earlier truck...but it's been done alot so it's no big deal. That's one SICK Blazer!
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A Last edited by 69BBsuburban; 01-24-2008 at 05:47 AM. |
#13 |
BAD BOW-Silverado XST
Basically, the reverse of this http://www.coloradok5.com/grilleswap.shtml
#14 | |
Happy to be here
