Old 01-20-2008, 03:21 AM   #1
69swbman
need some help
i just got my first standard hot rod its a saginaw 4 spd and was wondering if someone could help me out with this question how do u service the tranny (drain hole and fill) never serviced a standard always had automatics if someone could help thanks
69swbman is offline   Reply With Quote
Old 01-20-2008, 06:51 AM   #2
truckdude239
truckdude239's Avatar
Re: need some help
well u can pullt he driveshaft out and jack the front up it will drain that way for the most part, then refill till it comes out the hole
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-20-2008, 07:25 AM   #3
crazy longhorn
Fabricate till you "puke"
Re: need some help
Try pulling the lowest bolt for the tail housing.....IIRC, the hole goes through the main case). Jack er up as posted above, & just let it drip overnite. refilll,(you will find a plug on the pass side,about 1/2way up the maincase). It just needs to be @ the bottom edge of the threads ,with the truck back down on the wheels......or slightly dripping out the hole as stated above. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-20-2008, 07:26 AM   #4
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: need some help
You could get a siphon pump at the auto parts store and pump it out too. Threw the fill hole.
LOW DOUGH is offline   Reply With Quote
Old 01-20-2008, 07:30 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: need some help
That isn't such a good idea... it'll leave most of the crap laying in the bottom to contaminate the fresh oil that gets dumped in.
Old 01-26-2008, 06:12 AM   #6
69swbman
Re: need some help
thanks guys this place really helps YALL ROCK
