01-20-2008, 09:38 AM | #1 |
Oil on starter bolts
I was gravity bleeding the brakes and while I was on the front passenger side i looked at my new mini start and I noticed that there was oil on the bolts. When I swapped my rear main seal I did put a new one piece oil pan gasket on but I could not tell where the oil came from. This engine has not been started in 2 months. I checked the front of the pan to see it it was blow back from when it was started and it looks clean. Has anyone seen this before?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-20-2008, 09:50 AM | #2 |
Re: Oil on starter bolts
Mine always had oil on the starter/starter bolts, but then none of mine (till this one, which has yet to be started) were new like yours.
Possibly small leak from back of the intake or valve cover. Leak around the fuel pump mounting, or oil filter? Just wild a-- guesses though.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 01-20-2008 at 09:50 AM. |
01-20-2008, 12:19 PM | #3 |
Im going to get under there tomorrow and clean up the oil pan, around the oil filter, fuel pump, and flexplate. After that I should see where the oil is coming from.
01-20-2008, 11:33 PM | #4 |
Got the same thing on my Nova... Cant figure it out.... Its so minor though I havent really spent too much effort trying to figure it out... I will be curious to see what you find....
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
01-21-2008, 12:03 AM | #5 |
Dave's not here, man
When the rear of my intake was leaking I always had oil on the starter bolts. You could check that. Not sure what else could be the culprit.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
01-21-2008, 12:52 AM | #6 |
Parts and more parts
I agree, take a look at the intake or head rear area, then if that is dry the rear seal is dripping on engine shutdown and then getting a flipping action on starter crankover.
01-21-2008, 02:22 AM | #7 |
Broken Down
Don't overlook the dreaded valve cover gasket as well!
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
01-22-2008, 02:14 AM | #8 |
Junior Member
I agree - check the valve cover. My '68 camaro was dribbling a little oil from the starter area as well. I was afraid it was a pan gasket or rear main, but I eventually found that the rear corner of the pass side valve cover was leaking. Oil would run down the block and collect on the bottom of the starter, then drip on the floor. Turns out the cork gasket had pulled away from the corner of the cover just enough to let the oil by. New gasket did the trick.
69 GMC Sierra 1500 Custom 68 Camaro SS 18 GMC Sierra SLT Living the dream |
