Long Fleet Club
Well my truck joined an orchestra. All it likes to do now is play a nice high pitch sound (squeal). I tried everything I know to do and the pulleys look pretty much straight. But everything is from different engines. I have a MR Gasket 2 groove crank pulley; A long water pump with a 2 groove pulley; A power steering pump with a home made bracket (PO made) for the outer adjustment bolt; and an alt for a '84 305 Camaro with a stock bracket. Here is a picture (not the best though) of my belt system befor the new alt. but it was a while back when I got that and this started not to long ago.
![]() I'm also not opposed to changing everything but low on cash though. Almost to the point of parking it and just Ride my bike more. Here is a link to the classifieds section where I'm looking for a system
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 01-20-2008 at 10:01 AM. |
![]() ![]() Join Date: Jul 2002
Re: My truck the musician
Might be just the angle of the photo, but it looks like the alternator/crank/pump belts isn't quite tracking straight. Looks like the alternator is slightly back just a hair.
Long Fleet Club
I have 2 of the upper alt brackets and both have the bolt hole on the intake ground out to get the bolt in. Did sombody screw up at the factory when stamping these or is it for a diffrent setup?
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
Long Fleet Club
laying low
![]() Join Date: Mar 2001
Loosen one belt at a time and run it and you will find out which one is the musician there. The alternator belt is running down in the alt pulley pretty much. It could be it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
its all about the +6 inches
the power steering looks to be further forward than the water pumnp pully too.
Long Fleet Club
Ill try to get a better pic from looking straight down. At least it get quieter when the belts warm up
Long Fleet Club
The alt is the one that does it the worst. It threw the belt off last week. The P/S does it a little.
![]() ![]() What years of serpentine can I look for at the Junk yard that will work with this pulley setup
#9 | |
I've had belts that were 'use hardened' (but not cracked) that squealed alot. Also, an alt that has a bearing that's worn out can be a culprit too.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-22-2008 at 04:45 AM. |
Official Site Guitar Shredder
i would put a straight edge on both pulley and all pulleys this should help you....to me none of the pulleys look lined up to me........just my O.2
Junior Member
![]() Join Date: Aug 2006
I would definitly say that the alt and ps pump are to far forward. But I would also check the alternator. They make a high pitched sound when the bearings are bad, also the ps pump when they are low on fluid.
1970 C10 Short fleet side. For sale http://cgi.ebay.com/ebaymotors/ws/eB...MESE:IT&ih=017 |
Long Fleet Club
Both belts are new now. The old alt belt was as old as the alt. about 6 months.
What years of serpentine can I look for at the Junk yard that will work with this pulley setup?
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 01-22-2008 at 07:56 AM. |
#13 |
Prob 84-87 V6/V8 stuff. Alot then were partial serp set-ups w/some v-belt add-ons. It would prob be easier to go the 88-up brackets (S10 or GM trucks).
#14 |
Long Fleet Club
I'm just wanting to rip everything off from the front of the engine except for the balancer and the water pump and just replace it all if I cant get this straight. Would like to just replace the pulley on the alt to serpentine because I have a lifetime warranty and it is a 94 amp alt.
#15 |
I got everything I needed from a 94 4.3 V6 out of a C1500, bought new water pump (I needed alternator too as one I got was NG), and changed the fitting on the power steering pump so it would match the old style Hi pressure fitting.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 01-22-2008 at 10:13 AM. |
#16 |
laying low
It's really hard to be sure from these pics but I bet an 1/8" thick shim behind the water pump pulley will take care of this noisey rascal. I have seen these shims at the salvage yards before but don't know what they came off of. A man could make some if he wanted to.
#17 |
So you figure out what the cause was?
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
#18 |
Right turn Clyde
85? 86-87 Full size trucks have a wide belt for the alternator and v belt for the ps. Cheaper than a serp system.
#19 |
say,
i see something out of the norm here. when i here squeaky belts its usually cause of 2 reasons first they get old and dried out. second is what i see in your first photo. something sprayed the engine compartment be it oil, antifreeze, muddy water or what not. you say you put new belt on with the new alternator and it stated squealing sometime later. i would guess they got wet with something. have you tried a bar of soap. another old man trick. do this at your own risk. go get a bar of soap and run engine. be careful and run soap on the under side of belt. keep hands and sleeves away from belt and pulleys just put one end against the belt. it should make a slight groove on the bar and stop the squealing. remeber try this at your own risk. |
#20 |
blood type; Retumbo
getting a better ground will help some. right now it looks as though it is trying to ground through the painted alt. bracket.
you may also try a different brand belts. carquest is Gates. try Dayco or goodyear. |
#21 | |
Long Fleet Club
I had a belt from Oreily's on it (I think it was Kelly somthing)
#22 | |
Long Fleet Club
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 01-22-2008 at 04:06 PM. |
#23 |
just trying to help. yes i understand normal fluids should not effect the belt but i would say somthing has. have you tried the soap. it seems silly but everytime i have had squeeky belts i have done this trick and it fixed it everytime. you can put it on without running the motor by sliding it between the pullys. remember put it on the runing side of the belt. they used to sell belt dresser i dont no if they still do.
#24 |
Long Fleet Club
I know. I'm just getting tired of this engine and trans and new stuff is just out of reach. On top of it all I'm wanting to go serpentine but every time I think about it I go blank. I tried the soap thing befor but don't think I did it right. I'll try again tomorrow.
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 01-22-2008 at 04:11 PM. |
#25 |
Long Fleet Club
well I put the soap on but I tried something while I did it. I put some on the front side of the V first (side to the radiator) an there was little change then I put it on the back side (facing the engine) and it got quiet. I'm thinking the alt needs to be moved forward. the old W/P pulley was wore down on the back side of the grooves
