01-20-2008, 03:54 PM | #1 |
front sway bar mounts
does anyone know the dimensions of the front swaybar mounts between the frame and the swaybar ?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
01-20-2008, 11:11 PM | #2 |
Re: front sway bar mounts
I'll check this morning, Mine was a option from the factory. Also you need to post 1 more time to get away from the 666
01-21-2008, 02:38 AM | #3 |
If you've lowered yours any, the swaybar mounts need shortened up too.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-21-2008, 05:41 AM | #4 |
I not sure, what part of the frame? My stock sway bar has a factory bracket that levels it and then back to the a-arms so I'm not sure where to measure for you?
01-21-2008, 06:40 AM | #5 |
The Older Generation
I would say he wants to know the height of the brackets between the frame and the sway bar mounts on the front of it... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-21-2008 at 06:41 AM. |
01-21-2008, 07:20 AM | #6 |
From the center of the bar to the center of the bracket up to the frame is 2.5"
01-21-2008, 10:29 AM | #7 | |
what if i have the front lowered
01-21-2008, 10:52 AM | #8 |
Ever heard of Beech Island??
i saw where someone just mounted theirs right to the frame on their lowered truck. They just didnt use that brackett, and bolted the bushing bracketts to the frame
01-22-2008, 01:42 AM | #9 |
Tot Roddin'
I believe it was Frizzle Fry that mounted his directly to the frame. From what I've heard this is the way to go. If you decide not to go this way, ECE has a lowered bracket you can buy.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-22-2008, 02:08 AM | #10 |
laying low
I haven't tried it but just looking at the pics you should be able to flip the bushing and bracket onto the top side of the frame bracket gaining you a couple of inches more clearance. In other words runnning the bar through the frame bracket instead of under it. Should work.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
01-22-2008, 02:38 AM | #11 | |
LockDoc
01-22-2008, 05:58 AM | #12 |
Here's the link It's good for probably 3" of spring drop up front, but when I bagged it I had to space it away from the frame a bit.
01-22-2008, 06:04 AM | #13 |
Old Skool Club
I don't have a picture, but the ECE stabilizer relocator brackets will move the stabilizer bar about an inch (at least) closer to the frame horns. I didn't put mine on, yet, but have been careful in my travels and have only bottomed-out the front bumper on one nasty dip in the past six years. He shoulda stayed outta my way....took me about an hour to get him cleaned off of the bottom of the bumper.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-22-2008, 08:35 AM | #14 |
Dave's not here, man
Here's a couple of pics of mine with ECE brackets ChevLoRay is talking about:
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
