Old 10-18-2002, 09:59 AM   #1
williso
Sorting out option codes on glovebox sticker?
HI,
I've been looking at these for awhile, both on trucks I've seen locally and when people post pics of their option sheets, and like everybody else I've noticed that sometimes the codes are just 3 digits (for example C42 = heater) and sometimes they are 5 or 6 digits (for example C42AC = heater or 1C42AC = heater).
Anyway I've been trying to see if there was any pattern as to when the 3 digit vs 5 digit codes were used. Not too much luck so far, apart from seeing that it doesn't seem to be a Chevy vs GMC thing, and not a year-to-year thing either (I've seen 1972's with 3 digits and 1972's with 5 or 6 digits).
So far the only thing I've turned up that might explain it is the assembly plant. To be specific, every Flint , Tareytown, Atlanta, and St. Louis truck I've seen had 5 or 6 digits, while every Fremont or Baltimore truck had 3.
But I haven't seen all that many trucks overall, so I can't be sure if that's the real explanation or not. Anybody willing to look at their option sheets and post what plant their truck came from and what their option #'s look like so we can maybe figure this thing out?
williso is offline   Reply With Quote
Old 10-18-2002, 09:01 PM   #2
Hutch
Hutch's Avatar
My truck is a: 1968
Built in: St. Louis
Option's codes are: 6 digits
It would be intresting to see what the results are:
You might want to set this post up as a poll:
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-18-2002, 09:11 PM   #3
ckhd
ckhd's Avatar
I've got an example that will throw your plant theory out the window:
1968. Vin: KE248ZXXXXXX Z= Freemont, CA and it has 6-digit codes.
1969. Vin: KE149ZXXXXXX Z= Freemont, CA and it has 3-digit codes.
I've looked everywhere I can think of and there is no pattern. None of it makes sense.
If that doesn't confuse you enough, my '72 c10 has both three and six digit codes.
If you ever figure it out, I'd like to know, because I've given up looking.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 10-18-2002, 11:29 PM   #4
Brewski*
Brewski*'s Avatar
What does ABS on the shocks mean? I found it = Absorbers
Brewski* is offline   Reply With Quote
Old 10-19-2002, 12:20 AM   #5
mikep
Used to have a truck
mikep's Avatar
1968 Fremont ... 7 digits all the way down.
No truck :-(
mikep is offline   Reply With Quote
Old 10-19-2002, 08:39 AM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I would love to find a way to decode the 6 digit codes. Some of mine are very mysterious as they don't have a description next to them.
Both my 69 and 71 have these 6 digit codes.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-19-2002, 08:51 AM   #7
williso
Dang it -- another beautiful theory ruined by facts ! I guess it's just another one of the unsolved mysteries of the universe...
Old 10-20-2002, 12:24 AM   #8
roger0080
Ohhhh man. This option stuff is a can of worms when it comes to what plant did what. I have studied this for many years for Janesville, Flint, and St. Louis plants.
Here is what I can sum up:
All 3 plants up through 1969 used the 6 digit RPO codes, ie 1PV6AB etc etc.
Janesville in 1970 switched to the 3 digit RPO codes, ie PV6.
Meanwhile Flint and St. Louis kept on using the six digit RPO codes through 1971. Then for 1972 they still used the six digit RPO codes, but then last 2 suffix codes changed from Alpha to Numeric as in: "1A11AA TINTED GLASS" was changed to "1A1120 TINTED GLASS", ie "AA" is now "20".
Anybody know what the last 2 suffix letters such as "AA" or "20" means?? or the first number "1" in the example above? The suffixes can/could be different plant to plant, year-to-year, but generally are the same.
In 1972 the Freemont plant had some printed with all 6 digit codes, and then some with just all 3 digit RPO codes listed.
Then ... sometimes, on the same sheet, you may get a mix of both 3 digit RPO codes and 6 digit RPO codes (ie plants that used the 3 digit RPO as standard). It looks like when you get a true "mix" of RPO codes, the buyer was adding some odd/special equipment. Haven't heard of anyone with the GM books on here able to decode the oddball RPO's. The regular RPO's are easy to decode with a list.
Hope this helps! Yeah right!
-Roger
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 10-21-2002, 12:19 AM   #9
Fast68Chevy
Fast68Chevy's Avatar
same RPO code no matter if is 3 or 6 digit, just look in middle of the 6 digit codes for the actual equipment regular production code,
Fast68Chevy is offline   Reply With Quote
Old 10-21-2002, 08:04 AM   #10
bobs409
bobs409's Avatar
Wanna try these?
Bob
Old 10-21-2002, 08:23 AM   #11
roger0080
I've seen your option sheet posted before and can't make out heads or tails on the 9XX option codes. That is the weirdest build sheet I've ever seen.
I don't know who would have that kind of info to make sense of it.
-Roger
Old 10-21-2002, 09:11 AM   #12
Huck
Huck's Avatar
Wink
Option/build codes are a lot like women---sometimes when you think it makes sense~~~WELL~~~~~. I've come to the conclusion that sometimes it's better to leave things a secret!
"If a man is all alone in the middle of the forest and makes a decision without the aide of a women, is he still automatically WRONG?" If you have to ask the question~~~~~!!!! WTF-over!!~~Huck
Huck is offline   Reply With Quote
Old 10-21-2002, 09:58 AM   #13
racedvl
racedvl's Avatar
Thumbs up
Can someone please sort out my options please!! There are too many of them, and I don't know what they mean!!
racedvl is offline   Reply With Quote
Old 10-21-2002, 02:25 PM   #14
MStokes
MStokes's Avatar
My 72 came out of the Fremont plant and all of the listed options are three digits.
Racedvl, I hope at least a few extras have been added to that truck in the 30 odd years since it was manufactured.
1972 C-10 LWB, 400/350, 2WD
1972 C-20 Custom Camper, 350/350, 4WD (Converted)
MStokes is offline   Reply With Quote
Old 10-21-2002, 02:30 PM   #15
Project1970
14.1 @ 96MPH
Project1970's Avatar
Mine's a '70 GMC from Fremont and it's got 3-digit codes all the way too. IIRC, my buddy's '69 Chevy had 3-digits as well, but I don't know what plant...and it got totaled, anyway.
In fact...I think nearly every truck I've seen around here has the 3-digit codes.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 10-21-2002, 11:10 PM   #16
racedvl
racedvl's Avatar
Talking
The only ones that have been added have been by me.
Old 10-22-2002, 12:02 AM   #17
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
racedvl...bummer you didn't check the option for oil pressure huh?
Old 10-22-2002, 12:15 AM   #18
crazy longhorn
Fabricate till you "puke"
LMAO @ longhorn! I think that read oil gage on the glove box
crazy longhorn is offline   Reply With Quote
Old 10-22-2002, 12:20 AM   #19
mikep
mikep's Avatar
Am I the only one here with 7 digit option codes?
04625AC ....parchment/cloth interior.
Ive got 13 more like that . They all start with "0" . Fremont 1968
No truck :-(
