01-21-2008, 08:14 AM | #1 |
Broken Down
Alternator ??
Well my alternator started charging around 16 volts on my aftermarket volt meter. So I broke out my DVOM and checked it at the battery and it is charging at 15.94 volts at idle and around 16.20 at 2000 RPM. I repalced the alternator and external voltage regulator about a year ago. should I be too concerned or should I repalced the voltage regulator again??
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” Last edited by kenm78; 01-21-2008 at 09:40 AM. |
01-21-2008, 10:05 AM | #2 |
Re: Alternator ??
just throw them away and do this upgrade click here takes 30 misn i got my alt off and 83 chevy k-10 with 350 4bbl carb. my truck started charging at 19volts burned out my headlights and cd player. i replaced volt reg 4 times no luck finlly went witht he internal rega lt fixed all my problems
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-21-2008 at 10:06 AM. |
01-21-2008, 10:53 AM | #3 |
Re: Alternator ??
Agreed I upgraded to an internal, It is so much nicer and very easy to do.
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6 |
01-21-2008, 11:12 AM | #4 |
Freeeeee Mason...
Re: Alternator ??
I upgraded to a 240 amp internally regulated alt ... But then I'm running H4 headlights, and 3200 watts of amplifiers =)
01-21-2008, 11:28 AM | #5 |
Re: Alternator ??
I recommend taking a look at the Powermaster line of alternators. Ck our www.powermastermotorsports.com/gm.html. They have 100 amp and 140 amp models. Appearance wise they seem the same and are chromed or natural. I just put the 200 amp model in my 99 Silverado and that sucker answers all my power needs to spare. They seem to be very well made. And they have the 6 and 12 mounting position.
01-21-2008, 01:14 PM | #6 |
Broken Down
Re: Alternator ??
How many amps are our stock external voltage regulator alternators rated at and how many amps is the
ULTIMA 01-0260 38039301 Rated for in the conversion topic listed in the link above??
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
01-21-2008, 10:15 PM | #7 |
Re: Alternator ??
my stock alt was rated at 30 amps my new one was 65. only thing i ahve not strock is my cd player and cb radio
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-21-2008 at 10:15 PM. |
01-21-2008, 10:31 PM | #8 |
Re: Alternator ??
Not trying to jack this thread but I have a question. I put a one wire 140 amp alternator on my truck and the amp gauge always shows discharge until I turn on the AC then it points strait up. I have daytime running lights and a big amp on the stereo. Is it possible the amp gauge is wired backwards I put a painless wire kit in the truck. Always shows 13.82 volts at the altenator at idle or up to 2500 RPM
69 Chevy 4x4 383 Power |
01-22-2008, 05:22 AM | #9 |
Broken Down
Re: Alternator ??
My alternator is mounted on the passenger side with this style bracket will I have to change my brackets??? it is the style of bracte that wraps over the alternator and bolts to the water pump housing and the thermastat housing.
01-22-2008, 05:31 AM | #10 |
Re: Alternator ??
no the brakets will work just get an alt with the mounts at 6 and 12
like this one
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-22-2008, 05:35 AM | #11 |
Broken Down
Re: Alternator ??
the link didn't work for me
01-22-2008, 07:05 AM | #12 |
Re: Alternator ??
okay try this one it looks stock on mine noone will really know unless they look hard
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-22-2008 at 07:08 AM. |
01-22-2008, 08:21 AM | #13 |
Broken Down
Re: Alternator ??
Ok got it all completed!! I used the ULTIMA remanufactured alternator 01-0260 from Oreilly auto parts. took longer to get the part than to do the converstion. Thanks for the links and the help worked like a charm
01-22-2008, 10:04 AM | #14 |
Re: Alternator ??
yup know you will no longer have any trouble out of it!
03-11-2008, 07:58 PM | #15 |
Gettin By on Gettin By
Re: Alternator ??
When switching to internally regulated alt, do you have to change the battery guage in the dash too?? I swapped last weekend and hooked up the battery last night and now the guage is reading right in the middle all the time, even with key off. I must of did something wrong *no a big surprise*
03-11-2008, 08:23 PM | #16 |
Old member
Re: Alternator ??
The amp meter will alway's show something on it. Don't worry about it. If you want to take one of the small nuts off the circuit board on the back of the dash.
03-11-2008, 09:25 PM | #17 |
Engine n00b
Re: Alternator ??
Another vote for the internal regulator. Got mine from Austin Alternators. They do a lot of mail order as well.
03-11-2008, 09:52 PM | #18 |
Re: Alternator ??
Does a replacment volt meter to replace the amp even exist for straight OEM dash swap with out having to rig one up??
