Freeeeee Mason...
Center Caps, Beauty Rings
Okay, I have these old 15" rallies from before I put on my 22's and I was wanting to paint them black and put chrome Tri-Bar center caps on them. Does anyone know where I can find new ones that will fit these wheels? I could use some beauty rings too. My truck isn't a 4x4 but a PO slapped those ugly caps on there.
I really just want something pretty to slap on every once in a while... especially in the dirty winter months. I haven't had time to clean my wheels in a month and the chrome is looking pretty dirty. ![]() ![]() ![]() |
Re: Center Caps, Beauty Rings
I got my trim rings here http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
Freeeeee Mason...
Thanks. I've found quite a few places to get the rings, but none to get the center caps I want... anyone else have any ideas?
Truck and auto performance nut
OK.....here you go:
CHEVY-SPINNER-KIT-KNOCK-OFFS-3-BAR-WHEEL-CENTER-CAPS this looks about the same height as the OEM center caps? I was thinking take the knock off apart, put the stand under the center cap (with a center hole pre-drilled in it). Then just screw/bolt the knock off top thru the center cap to the mount? Or, do it the way they say (from behind ![]()
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
What kind of shape are the 4x4 caps you have pictured in? May be interested in them, I have a 4x4.
Thanks Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#6 | |
Freeeeee Mason...
They're in horrible shape. I think I have 3/4 of them but the last one is missing the center part that says 4x4. That is about the nicest looking one. Ps... I have 6 lug wheels remember. Not 5. Those only fit 4/5 lug. |
then don't use the stand....use the standard center caps for the knock off stand... and drill the hole to mount the spinner on top?
Old Skool Club
![]() Join Date: Jun 2001
The one that doesn't have any logo in the center, i.e., has a hole, should be for the front hub of a 4X4 truck to stick thru.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Freeeeee Mason...
This is true... but it also means I have three caps for the rear and one front one =)
annies hub cap in chattanooga, tn could probably find you what you need. i have had great success with these people. phone: 423-855-4432
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
6-lug rallyes only came on 4wds.That`s why there are as many open caps as closed and they say 4x4 on them.Most guys find spinners and bolt them to the caps.I don`t think anyone makes a spinner center cap for 6-lug.
and a few others
I'm with Special-K, I don't think anyone makes one. I wish someone would.
The biggest problem, the clearance/tolerance between the hub and the hole in the wheel is almost "zero." So a cap that would slide in from the rear like a lot of custom aftermarket wheels wouldn't work unless it's paper-thin. Whatever you find will have to bolt on from the outside of the wheel just like the stock ones. ![]()
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
#13 |
SLOW BUT SURE,BUT CLOSER
Wheel vendors at most swaps has 'em. Around $ 75-100 should do it.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
