what ways are possible to have a rear roll pan with a hidden hitch (flip-down license plate)? are only certain styles do-able? i'd like to have a roll pan with the flat bottom all the way across. where have people gotten their pans and how did they like em? which hidden hitch kits seem to perform the best? all input is welcome.
![]() '74 GMC 3/4 TON 2WD LB |
The One And Only !!!
Re: rear roll pan w/ hidden hitch
Almost any can be done if recessed for the plate, I plan on this one;
![]() http://www.mar-k.com/catalog/catalog.asp Going to build my own hitch to tuck up under tightly so can't be seen at all. Also build my own spring loaded license plate bracket to swing open to the left, Use a extended receiver so johnny can see my plate while towing. That's if I ever decided to tow anything.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
here is what i am going with!
http://grantkustoms.com/catalog/prod...products_id=56 |
