Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-22-2008, 02:38 AM   #1
scott's69
WORTHLESS CRUISERS
scott's69's Avatar
oil lines
Has anyone replaaced the oil lines on their blazer? Ive got a 99 that has leaking oil lines. I was looking for any suggestions on how to do it yourself.
Scott Hammond
Lancaster, SC
1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454
If you don't live for something, then you'll die for nothing. www.xclusive-images.com
scott's69 is offline   Reply With Quote
Old 02-08-2008, 09:52 AM   #2
Montini
Montini's Avatar
Re: oil lines
I have a 99 xtreme. Had to replace lines two months ago because they were leaking bad, about a quart in 20-30 miles. Bought lines at o-reilly's for about $40. Took about 45 minutes to install and clean up. Just raise vehicle and put on jack stands. There is a 10mm bolt that holds the lines onto the oil filter adapter, remove the bolt and the lines are free. There is one clamp bolted to the driver side front of the oil pan, remove it. Then you remove the special clips that hold the lines to the radiator, I used a small dental type pick/hook to remove the clips. Then just remove lines. Install new lines in reverse order and check for leaks. I had a little trouble installing lines back into the radiator and had to slightly bend the new lines to fit like the factory ones. I found it easier to install the special clips after the lines are fully seated. I also had to remove my cold air intake to make room for replacing the lines. Hope this helps.
Montini is offline   Reply With Quote
Old 02-08-2008, 12:14 PM   #3
bwood
bwood's Avatar
Re: oil lines
When you go to buy it, take your old one with you. When I worked at Oreilly, we sold (6) different oil cooler lines for the S-Series trucks. Three are 3 different return lines and 3 different supply lines.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 02-08-2008, 04:56 PM   #4
scott's69
WORTHLESS CRUISERS
scott's69's Avatar
Re: oil lines
I forgot to mention that mine is 4WD. The front differential is in the way. It must be moved to get to the oil line from the engine. Ive already replaced the line to radiator. Used a GM line from dealership. Im just looking for suggestions so I wont run into any problems.
Scott Hammond
Lancaster, SC
