Old 01-22-2008, 03:48 AM   #1
whatnow123
whatnow123's Avatar
stepside fender attachment?
Hi,
What should I put between the fender and the bedside when reinstalling my fenders? Will a good bead of seam sealer do the job or should I use the "kit" that the vendors sell?
Thanks!
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-22-2008, 06:53 AM   #2
JimKshortstep4x4
Re: stepside fender attachment?
I used the beaded material plus a good Ureathane sealer in making sure it would not leak between the fender and bedside. Although it does not leak, I am dreading the day when I have to remove a fender as it will probably be stuck.
If I had it to do over, I would go with a good layer of 3M strip caulk without the beaded material.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-22-2008, 08:14 AM   #3
krue
Designated A-hole!
krue's Avatar
The welting sticks out to me, just use a good seam sealer, thats what the factory used.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-22-2008, 10:30 AM   #4
mvfd70
mvfd70's Avatar
What about welding the gap between the fender and bed. Anyone done this? Or is that a bad idea. I havn't done it but wondered about it.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 01-22-2008, 12:19 PM   #5
whatnow123
whatnow123's Avatar
Thats a question for Frizzle Fry, LFD or Porter, they all have sic welding skills. I could weld it on there, but then to make it look right is a whole other story.
Build thread:
Old 01-22-2008, 01:47 PM   #6
Mudder
Mudder's Avatar
I think welding is a bad idea. If you ever damage a fender you would have to replace the fender and a bedside. You would never be able to remove it. If both surfaces are painted some of the orginal dumb dumb would work. I went with the beaded felt. Lots less messy. It would also be hard to weld the top of the fender without taking a chance of burning holes in it.
Mudder is offline   Reply With Quote
