Old 01-22-2008, 05:10 AM   #1
fuelpump
fuelpump's Avatar
Wiring help
Here is a picture of the fuse block on my 60. I've looked through both the shop manual and the operators manual and couldn't find out too much about the fuse block which I assume is the original. As you can see it doesn't look like many of the fuses are being used. Some of the metal fuse holders are missing. Can these be replaced and if so where can I buy some? As you can see most of the wires are pluged in to the terminals on the left side. When connected here are these wires fused or unfused? I want to hook up a radio and my dome light (and want them to run through a fuse) but I'm not sure how to do it. Thanks.
fuelpump is offline   Reply With Quote
Old 01-22-2008, 08:17 AM   #2
kris's66lwb
resident wrencher
Re: Wiring help
just plug them into the rigt place and there fused
kris's66lwb is offline   Reply With Quote
Old 01-22-2008, 10:37 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Wiring help
Unfortunately, someone has hacked the fuseblock. You're missing the fuse clip ends. I don't think you can buy them at your local parts store. Hopefully someone here will know where you can buy them. If you remove the fuse block, the can be replaced from the back.
Your fuse block is labeled with which fuse controls what, just below each fuse. But that doesn't help much when you can't plug in a fuse.
Another option is to buy a small fuse block, parts or hardware store. You can also buy in-line fuses. But it will be better if you can fix what you have.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-20-2008, 10:16 AM   #4
David Flores
David Flores's Avatar
Re: Wiring help
Mine are missing those also. I'm going to try to replace them with an spare block that I have. But I do not know where the wires go..
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
