Old 01-22-2008, 09:21 AM   #1
jwn1975
Frame Cutting Behind the Cab
I know there is a post on cutting the frame under the cab to make a SWB but im wondering if there is any info on doing it BEHIND the cab. I know its been done. I just dont want to lift up the cab.
jwn1975 is offline   Reply With Quote
Old 01-22-2008, 09:23 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Frame Cutting Behind the Cab
Leaf or coil?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-22-2008, 09:25 AM   #3
jwn1975
Leaf spring, sorry
Old 01-22-2008, 09:27 AM   #4
Hart_Rod
Hart_Rod's Avatar
45 degree cut:
http://67-72chevytrucks.com/vboard/s...d.php?t=232149
Step-cut:
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
EDIT: I guess I should read the post a little more carefully. There should be 12" straight inches of frame between the cab and the front shackles. You should be able to cut that out using a 45 degree cut or a step.
Hart_Rod is offline   Reply With Quote
Old 01-22-2008, 09:29 AM   #5
crazy longhorn
I dont see a probnlem cutting behind the cab on that one......the reason the coil trucks are cut under the cab is cause you dont have to mess with moving the crossmember for the trailing arms. What yr is the truck?
Old 01-22-2008, 10:08 AM   #6
wibilly
wibilly's Avatar
mine was cut behind the cab by a prevous owner. straight cut and boxed. not how i would have done it but it's been over 10 years now with no problems and was used as a mud truck before i got it
common sense isn't so common anymore
wibilly is offline   Reply With Quote
