Old 01-22-2008, 01:12 PM   #1
otsenre
otsenre's Avatar
Front frame cutting
I have a short 4x4 frame that I noticed has been worked on. Has weld spots and original rivets have been replaced at front crossmember with bolts. Also horns in front are bad. I have another longbed frame (straight) and want to cut just beyond crossmember on both frames and replace. Has anyone replaced sections off frame. How will it affect the 4x4 leaf springs. Also is a 45 cut reccommended? Thanks in advance
otsenre is offline   Reply With Quote
Old 01-22-2008, 01:51 PM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: Front frame cutting
My best advice for welding on frames is a 45 degree angle cut on both edges and then fill in with the weld, much stronger weld from what I understand. But be careful if you dont have a frame jig and your measurements are off you could be in for some trouble
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
