Old 01-22-2008, 02:20 PM   #1
skokie
skokie's Avatar
Heater controls bolt to hold it in place
I had to replace the heater controls on the 68 and the previous owner drilled out both of the bolt holes and put in bigger ones. No idea why but now I have new heater controls and no way to lock it down. Does anyone know what size the bolt or screw is that hold this down to the dash?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-22-2008, 10:01 PM   #2
Sweet72
Sweet72's Avatar
Re: Heater controls bolt to hold it in place
Mine have 2 sheet metal screws that are about a #12 X 1", don't know if that's correct or not. If the holes are oversize now, just use machine screws and nuts.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-23-2008, 04:34 AM   #3
skokie
skokie's Avatar
Bought them today and its installed. Heater works good to
68 build thread
