Old 01-22-2008, 04:43 PM   #1
GMC70c20
pics of a 2" drop
I am thinking about dropping my 1/2 ton 2in in the front and 4in in the back. Does any one have a pic of there truck with this stance? and can I use my stock spindles and control arm with a shorter spring to drop my front end?
GMC70c20 is offline   Reply With Quote
Old 01-22-2008, 09:07 PM   #2
HotRodYJ
HotRodYJ's Avatar
Re: pics of a 2" drop
Yes you can. I'm running 2" springs and dropped spindles on my 71. There's no reason you couldn't run the 2" spring alone.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 01-23-2008, 12:11 AM   #3
blu87
blu87's Avatar
2" springs in front, 1 leaf removed in the rear, monroe sensatrac shocks all around...rides good.
Gene
blu87 is offline   Reply With Quote
Old 01-23-2008, 12:23 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
GMC70c20,... I like using the "stance photos" from ECE. (Early Classic Enterprises) This will show you what each drop will look like. Just remember,... when changing your OLD front springs for NEW drop springs,... you might not end up 2" lower. Most likely your springs are sagging at least 1" now. Here's a link to the pics. http://www.earlyclassic.com/tech.asp...nce%20Photos-2
Keith
Convert to disc brakes.
