Old 01-23-2008, 07:03 AM   #1
DANTES JIMMY
DANTES JIMMY's Avatar
Question Amp Gauge
Hey All Gotta Question
I Have A 72gmc Jimmy 4x4 350 Auto
And My Alternator Was Changed To A Internal Regulated By The Previous Owner Havent Found His Repair At The External Regulator
But My Amp Gauge Shows Discharge At All Times (except At Key Off)
I Read Somewhere
That The Small Wire Off Of Alternator Goes To Volt Gauge
So Does This Dude Have My Amp Gauge Reading Volts??
I Havent Gotten Too Deep Into It Yet
Thought I Would Get Some Ideas Before I Get To It
The Prev Owner Wasn't Much Of A Mechanic And Do You Really Run All Of The Currrent From The Alternator For The Whole Truck Through The Gauge??
Im Lost
No Fires Please Lol...
DANTES JIMMY is offline   Reply With Quote
Old 01-23-2008, 10:15 AM   #2
JimKshortstep4x4
Re: Amp Gauge
The amp meter on these trucks read the flow of electricity based on wire resistance over a length of about 3 feet so only a very small amount of power goes through the gauge.
I would suggest hooking a volt meter to your battery with the engine running. Voltage should read approximately 14.5 volts if the alternator is charging.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-23-2008, 11:03 AM   #3
DANTES JIMMY
Re: Amp Gauge
I Forgot To Add That To Original Message
At Batt I Am At 14.5-15 Volts So Im All Good There
