Old 01-23-2008, 07:06 AM   #1
shortbus2
C-10/C20 frame difference
My first post here.
Can anyone confirm the difference in material thickness between a c10 and a c20 frame. Are they the same strength wise? I'm going to be doing alot of trailer pulling and want to start in the right direction.
I don't have a truck yet but I've been looking hard.
shortbus2 is offline   Reply With Quote
Old 01-23-2008, 07:25 AM   #2
haysonj
haysonj's Avatar
Re: C-10/C20 frame difference
I had both a long wheel base 3/4 ton and a short wheel base 1/2 ton and I could not see any difference in metal thickness may be a difference in strength though
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 01-23-2008, 07:32 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the thickness and the size of the C chanel is the same. The 3/4 ton does have added braces, esp on the coil sprung version.
The main advantage to the 3/4 ton is the heavy duty brakes and rear axle with full floating hubs.
Old 01-23-2008, 10:18 AM   #4
shortbus2
Ok, thanx. I have a 14bolt rear with disc brake conversion and a Dana 60 front axle. 4x4 trucks are very hard to come by where I live. So, a 2wheel drive is what I'm going to start with. I've converted a 65 Chevy to 4x4 and it wasn't to hard.
Is the extra bracing on the 3/4ton frame, used to beef up the coil mounts?
