Old 01-23-2008, 08:28 AM   #1
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
So what did I mess up?
Truck was fine (of course) except a few lights in the gauge cluster. I took the cluster out, checked all the lights. I couldnt find any burned out lights so I put it back together. Now the generator light is on. Its kinda dim. However, its on.... I checked the alt and it seems to be charging fine. Is this the ground issue I keep hearing about? any ideas are appreciated.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 01-23-2008, 09:26 AM   #2
corn
Re: So what did I mess up?
Mine did the same thing the first time I pulled the cluster but it was the turnsignal lights. I ended up adding a ground strap from the metal frame to the dash & it solved my problem. So, ya its probably that ground issue.
corn is offline   Reply With Quote
Old 01-23-2008, 09:34 AM   #3
HavinSomeFun
Thanks, I will get a ground to it and see what happens. I know it can't hurt!
So I wonder why all my lights don't work.
