Old 01-23-2008, 09:27 AM   #1
jeff1vol
jeff1vol's Avatar
Can someone help with a dash pad install?
I've searched the forum and cannot find anything regarding this.
I need to replace my dashpad and I'm trying to remove my old one, but for some reason it won't come loose after I remove the four screws. How else are they attached? Did they glue 'em or something? Any help would be greatly appreciated!
jeff1vol is offline   Reply With Quote
Old 01-23-2008, 09:30 AM   #2
JimKshortstep4x4
Re: Can someone help with a dash pad install?
There are 6 or 7 stamped 3/8" nuts holding the pad on from underneath. I usually pull the glove box and dash to get at them but if you contort enough and have the right tools you can get at them. (If you don't have AC).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-23-2008, 09:34 AM   #3
Rollie396
someday it will be done!
Rollie396's Avatar
.Be warned however,changing the dash pad and pulling the cluster and glovebox was exactly how my worktruck turned into a full frameoff build...
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 01-24-2008, 12:56 AM   #4
jeff1vol
jeff1vol's Avatar
Thanks! I appreciate your help!
Old 01-24-2008, 01:30 AM   #5
lks dcvn
lks dcvn's Avatar
Some get lucky and the end bolts are missing (or not installed) - looks like yours are still attached at the ends.
Some people don't use the end bolts when installing it - to make that next time they need to replace it or remove it that much easier...
lks dcvn is offline   Reply With Quote
Old 01-24-2008, 03:49 AM   #6
Orange
Licensed to Thrill!
Orange's Avatar
What they said - plus some patience.
A 1/4" swivel or universal makes the job a lot easier as well.
If you are putting a radio, center vent, cluster, ANYTHING else in the dash, put it in after you put the dash pad on.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 01-24-2008, 04:01 AM   #7
GMT900
GMT900's Avatar
Disconnect the neg battery terminal first. You short the hot lead on the headlamp switch if to touch it with the wrench or extension.
The puppy barks but the trucks roll along.
GMT900 is offline   Reply With Quote
