convert elec trans to man gauge speedo
I put a nv3500 in my truck and I want to get the speedo working.
its like 200 bucks for the speedo and 50 for the sender I heard that there is a conversion box that will work buy never looked into it anyone know where I could get one thanks |
Re: convert elec trans to man gauge speedo
ttt
I did that trans conversion but ---the "box" that actually takes an electronic pulse and converts it to a manual cable---was way expensive --like $350. some 5-6 years ago. so I drove my truck using the tach for speedo info. Can't remember the name of the company but it was available --Do some searching on speedo conversions via google and you may find the company--think it was in the midwest someplace~~.
You should be able to convert it to a manual speedo by replacing the electronic components with manual one. Drive gear, driven gear and housing could be used from a 700r4.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
The Older Generation
You might find something here... Everything you ever wanted to know about speedometers. http://www.transmissioncenter.net/sp...n_______va.htm LockDoc
![]() Join Date: Jun 2002
its called a cable X box by Abbott Co. Works good too. http://www.drivetrain.com/abbottspeedo/abbott.htm
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
Cable X as mentioned above......works great. You can also set dip switches to scale your speedo for gear and tire changes.
