01-23-2008, 11:43 AM | #1 |
Old member
Debating if I should
OK,
I want opinion's on if it's worth it to take the driver's side fender loose and take the shim's out of it to see if the gap closes up enough to hide the rubber bumper like on the passenger side. The door want close good either on this side. The passenger side seem's look better and the door closes fine even with new rubber installed on both door's. I took these pictures to help with my problem. In the pictures you can see the rubber hood bumper on the driver's side and barely see it on the passenger side. Pic 2 and 4. Tell me what you think. Driver's side: 1. 2. Passenger side: 3. 4.
01-23-2008, 11:45 AM | #2 |
I have a radical idea!
Re: Debating if I should
I would do it. Little stuff like that drives me nuts!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
01-23-2008, 11:53 AM | #3 |
Old member
Me too! I just hate to take a chance of scratching it up. I guess I need to though or it's going to drive me crazy in the long run.
01-23-2008, 11:57 AM | #4 |
If you can get the wipers and cowl grill off without scratching anything, it should be pretty easy to do it.
01-23-2008, 12:05 PM | #5 |
Old member
That should be OK I have the wiper tool. I guess I have another project to do this weekend.
01-23-2008, 04:52 PM | #6 |
Cover your edges with masking tape first; should help protect the paint.
01-23-2008, 07:44 PM | #7 |
I`d do it.On the passenger side back corner I`d be concerned about the paint busting off that edge,too.
01-24-2008, 08:38 AM | #8 |
Old member
Took the cowl off tonight. Took shim out of front of the fender under the cowl. Tightened it back up and it didn't make any differance. What else do I need to do to get this gap right.
01-24-2008, 08:56 AM | #9 |
looks to me like you driver side hood hindge could be worn andbe the culpret
common sense isn't so common anymore |
01-24-2008, 10:50 AM | #10 | |
Old member
wibilly
01-25-2008, 10:23 AM | #11 |
Old member
Well I got most of it out. It's a lot better than what it was. The hood hindges where the problem. When we installed the hood we had it to far up on the driver's side hindge. Took a few tries but it's a lot better. I can live with it now. THANKS!
