Old 01-23-2008, 12:41 PM   #1
shaneschevys
Its always something!
shaneschevys's Avatar
3/4 ton question
Are the 73 & newer lower 3/4 ton a-frames the same as the 67-72 3/4 ton lower a-frames.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 01-24-2008, 12:20 AM   #2
airdale94
airdale94's Avatar
Re: 3/4 ton question
I think the only differance is the ball joint. The hole is either bigger or smaller. It might be the upper that is different. Are you looking to do a swap?
If you have a 68 or newer you can swap everything and leave the crossmember in. Then use the drum brake hoses and the mount on the back of the crossmember.
airdale94 is offline   Reply With Quote
Old 01-24-2008, 01:00 AM   #3
shaneschevys
I am using the 88-98 light duty 3/4 ton spindles on my 69 panel. One of the mods is I have to use a 3/4 ton lower a-frame so I can use the 88-98 ball joint. I already have a 77 3/4 ton that I can rob them from.
79 p10 stepvan
72 Short Fleetside
72 Suburban
64 Short Fleetside
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Old 01-24-2008, 09:30 AM   #4
wibilly
wibilly's Avatar
i know the lca bushings are different but don't know if they are interchangable
common sense isn't so common anymore
wibilly is offline   Reply With Quote
