Old 01-23-2008, 01:12 PM   #1
79GMC_OLDS
79GMC_OLDS's Avatar
1/2 ton with 1 ton srpings and shocks
On a 2wd truck, can you put springs and shocks from a 1 ton on a 1/2 ton? Are the springs the same length just different strengths?
thanks
79 GMC Sierra 5.9 cummins, nv4500
79GMC_OLDS is offline   Reply With Quote
Old 01-23-2008, 01:25 PM   #2
chev74
Addicted to Chevy
chev74's Avatar
Re: 1/2 ton with 1 ton srpings and shocks
i am definite about the springs, not sure on the shocks, but i dont see why not. I have done the springs before - BEWARE its a stiff ride
chev74 is offline   Reply With Quote
Old 01-23-2008, 01:39 PM   #3
abebummy26
abebummy26's Avatar
Ru speaking of fronts or rears.
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 01-23-2008, 02:06 PM   #4
89 crew
The center bolts will be a different size so you will have to either drill out the rear axle holes, or grind the head of the center bolt down to fit.
89 crew is offline   Reply With Quote
Old 01-23-2008, 09:14 PM   #5
79GMC_OLDS
79GMC_OLDS's Avatar
sorry i was talking on the front. need something that can take the weight of the cummins a little better
Old 01-23-2008, 10:17 PM   #6
Pyrotechnic
Pyrotechnic's Avatar
1 ton coils shouldn't be all that harsh with a Cummins 6BT on top of them. I also recommend Monroe Gas Magnum shocks.
Pyrotechnic is offline   Reply With Quote
Old 01-23-2008, 10:54 PM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
There is also a heavy duty front spring option for half tons. I used to have them on my '86. Most of the auto parts stores carry them for about $80-$90 per pair.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-24-2008, 12:57 AM   #8
chev74
Addicted to Chevy
chev74's Avatar
I would also reccommend the Monroe shocks. All the old techs around my town love them.
Old 01-24-2008, 01:06 AM   #9
89 crew
For the fronts look for a set of coils for a 1/2 ton with a 454 or any other big block and you should have what you want easily.
Old 01-24-2008, 02:23 AM   #10
79GMC_OLDS
79GMC_OLDS's Avatar
my truck was originally a diesel so it should already have heavier springs in the front. Im not sure what they are the equivalent of but i assume 1 ton would still be stiffer. So they will fit?
