Embrace the Redneck
Key won't kill it and the needles won't move. Help?
I need some help.
The key will not kill the truck. - I've changed the switch thinking that was the problem but it wasn't. - I rewired one wire that I think went to the starter, I dunna know. The temp guage stays at about 75% twoard Hot - It did work at one time when I put the engine in it and it had a new sending unit in. The ammeter I'm not sure ever worked even with the old voltage reg. I know the wiring is correct there. Ideas? it's the '68 in my sig.
'01 Camaro Son, you just can't get there from here... |
Re: Key won't kill it and the needles won't move. Help?
It sounds to me like you have a short in the loom. I don't know how many wires are damaged but for the engine not to die it has to be getting power to the hot lead to the distributer. my guess would be track that and you will find the rest when you find it.
#3 | |
Embrace the Redneck
Or just replace the whole under hood harness....
#4 | |
start at the fuse block on the firewall and trace wires, maybe you will get lucky and find it there. as for the gauge try adding a ground wire to it. that was the problem i was having on my gauge
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
It's a catastrophic success.
![]() Join Date: Jan 2003
Check your starter again, make sure the purple wire is on the "S" and the other is on the "R". If you swItched them it will cause some of the problems you described.
![]() Join Date: May 2005
Just a question...What do the "R" and the "S" stand for??
Thanks |
The Older Generation
"R" is for "Resistor" and "S" is for "Solenoid" LockDoc
#8 | |
Embrace the Redneck
There's a Green, or it may be purple, wire that I disconnected from the starter due to length and just wired it into a direct off of the battery wire but i could shake it and the truck would die. the guages have always been a problem, from day one. I be there's a shor there. I really do need to replace the under hood harness... anyone got a nice one and one that isn't falling a part? LOL sswj
The "R" wire is a direct from the sol to the coil to bypass the resistor wire on the ign, so you get a full 12v on start up, If you hooked this wire to a power source then you are direct feeding the coil and it wont turn off.
#10 | |
Embrace the Redneck
I bet it's that one.
I miss this truck.
Yeah, if you've got issues with all of your gauges, that would make me suspect the ground strap from the gauges to the dash. I'd pull the bezel and check it out.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#12 | |
Did it come disconnected from the sensor? Sometimes times the will "stick" in a certain resistance and stay at that reading when disconnected.
#13 | |
#14 |
Embrace the Redneck
who is uncle?
