Wheel Openings Are Different!
Just got the correct fender skirts for my 64 Suburban. Just FYI, the Suburban rear wheel openings are the same as the short fleetside wheel openings. These are about 3 inches shorter, lengthwise, than those from the long fleetside and the panel truck. Who'da thunk it?
![]() Join Date: Sep 2007
Re: Wheel Openings Are Different!
![]() Join Date: Aug 2005
I would not have expected that either. Good info.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Huh! I never knew that after all these years....thanks for the info.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-24-2008 at 01:59 PM. |
LIGHTMUP,BURNMDWN!
your right !!!!!!!!!! ive been making skirts for my lwb using an old swb bed side as mock up! just read this and ran out side, good thing i found out now only having 2 hrs into them and not the projected 10 that i planed on!
64 LWB Chevy " EL DEVILLE" 61 Caddy ambulance 56 Coupe deville 64 Coupe deville 29 Ford roadster |
LIGHTMUP,BURNMDWN!
new can of worms!!!!!!!!!! installing the swb wheel openings on to the lwb!! one more weekend behind shcedule!
1961 crewcab
found some pics that should show the difference.
I knew the brown/tan truck had a cut down long bed, but I could never place why it looked good until now! I think I will go with the big openings on mine. |
UCA63
Funny how things hide in plain sight
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
Forcedinduction,
I didn't mean to come across as an A$$, he and I have traded Pm's about visors and skirts for Burb's and I wanted to see the skirts he bought on his burb. So I threw that out there to try and induce pictures posted. If it got under your skin sorry about that. |
Wow, I never noticed that!
I have never seen that green truck before. That is a dman nice truck
#13 |
except for that hideous tailgate!
#14 |
#15 |
1961 crewcab
just to clarify.. the wheel openings on the panel are longer than on a sub?
so it would be panel / long fleet and suburban / short fleet? thanks.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#16 |
Senior Car Nut
![]() Join Date: Jan 2008
well I'll be, all this time I just assumed. I'm planning on using my old lwb fleetsides on my panel so I'll be OK, but this is good info to know.
even with those two pictures above, I can't really tell a difference
Larry Last edited by fleetsidelarry; 02-14-2011 at 07:24 PM. |
#17 |
I have a short and long fleetside bed here, long bed at the bottom opening is around 36" and the short is around 33"
#18 |
wanna sell the short bed?
65 Chevy short fleet 350 5 speed, soon to be LSX powered 65 F100 short fleet 91 Heritage softail 94 Fatboy 11 Softail Deluxe [wife's bike] 13 Streetglide http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz |
#19 |
Just here to tinker
![]() Join Date: Jun 2008
and is it just the pictures playing tricks on me, or does the front of the opening on the shortbed seem more straight up and down (perpendicular to the ground) than the long bed opening in the front? I am going to go look at my long bed and my suburban tomorrow when there is daylight. This is very interesting....
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#20 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Long bed cut down.i like the bigger wheel opening.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#21 |
![]() Join Date: Jan 2011
That 3" differance must be why the short beds look like the wheel is sitting a little forward in the wheel well and the long beds don't look that way.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#22 |
#23 |
![]() Join Date: Oct 2006
so were can I get some skirts? ( for a long bed)
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#24 |
![]() Join Date: Oct 2009
Corts - excellent question. I "think" they are the same (i.e. the forward edge) and what you/we are seeing is just because of the angle from which the 2nd photo is taken. Now that we all are seeing something we aparently never saw before (amazing!) maybe we're looking for too many more "hiding in plain sight" things. Or, I'm full of crap and the front edges ARE different!
What's bugging me, and the one question I haven't seen answered is "why" did GM make 2 different size wheel openings? I can't imagine why a longbed and panel would need a longer opening that a shortie and suburban... Maybe the extra 3" just just looks more proportional in the long bed?? Hmm. As for me, shortys all the way - I think the shorter opening surrounds the tire better. I'm just glad they all look good. |
#25 | |
![]() In reality, IMO, those big wheel well openings look great with 33" and larger dia. tires sizes. No different than making the rear wheel wells bigger on a car being set-up for drag slicks. Novas, Camaros, Vegas... pretty common place then and now. Maybe the answer is they did it for the NAPCO trucks??? Something for everybody here I guess. It's all good. John Last edited by lakeroadster; 04-26-2011 at 11:08 PM. |
