Alright Alright Alright
motor misses at highway speed
i notice that lately when i get on the highway for about 5 min or more, my motor starts to have a low drone and loss of power. i can tell that its not firing on all 8 at that point. i then pulled over at a gas staion to see if there is a burned wire arcing on the header which i has done before. everything was in check. i got back on the highway and it was good for another 5 min before it resumed missing. what could cause this? the i also heard a clicking coming from the pass. valve cover.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Re: motor misses at highway speed
Plugs, Plug wires, vacuum advance issue~~~~. That's what I would look at.
Old Skool Club
![]() Join Date: Jun 2001
It's called "Sometimin'...." Sometimes it runs okay, sometimes it don't...
From your description it's really hard to diagnose via internet. There's a lot of conjecture and supposin' to be done on our part, much of which won't do you one bit of good. You should find a mechanic/friend and let him/her ride with you when you're sure it's gonna screw up.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
after reading an indepth article on how you should use manifold vacuum instead of ported on the advance, i put it on the manifold vacuum. could that be a reason?
Out of the carpool lane.
I'm having the same problem-especially in 5th gear and going up slight hills...it's like it's running lean or something. I haven't had the desire to look into it since it's too cold outside.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#6 | |
Look at your cap....cracks and carbon tracks in particular.
