01-24-2008, 06:39 AM | #1 |
Oem style "ribbed" vacuum line availability?
I like to keep things looking as stock as possible. Any one have a source for these lines?
1972 K-10 SWB Cheyenne |
01-24-2008, 08:14 AM | #2 |
Re: Oem style "ribbed" vacuum line availability?
try these guyswww.restorationspecialties.com
01-24-2008, 09:58 AM | #3 |
Again go to ricks and search white stripe vac line. This is the correct line for these trucks. If you will look around their online catalog you will find many of the parts you need to correctly detail your engine to stock specs. The camaro people reproduce everything needed to restore their cars and if you will look many of the parts used on the camaro as well as some of the big cars used some of the same parts, brackets etc. B/U light on 67 is cargo light on truck, pedal trim is the same as 71/72 higher end trucks you get the picture. Also check with National parts depot - the evap drain tube used on the trucks is the same as cars and it comes with the correct corbin wire clamp- ask many truck places and they will look at you like you are crazy. Good luck and good hunting.
