01-24-2008, 09:59 AM | #1 |
motor knocking
Hi all I have a 79 1/2 ton 4x4 that the only thing its ever been used for was plowing and the body is shot! It has a 350 and has always had a knock and i have babied it cause its mainly for plowing my long driveway. Yesterday i pulled it out of the shed and it locked it up and wouldnt start till i got a booster charger on it. It was stuck and when it came free WOW did it knock then!! I guessing its a rod problem it still has 20 lbs oil pressure and runs ok but is very noisy. My question is what can be done to limp it by till spring so i can junk it!! I poured in a quart of stp but didnt know if anyone had any other ideas. I dont want to tear the motor down its to dang cold for that! How many quarts of oil can I put in it and would that help at all?
Thanks Todd |
01-24-2008, 10:05 AM | #2 |
BAD BOW-Silverado XST
Re: motor knocking
A rod knock is only a time bomb. It can fail at any time. The bearings will fail eventually. Keep the RPMs low. If the oil pressure is only 20 PSI, it won't last long.
01-24-2008, 10:11 AM | #3 |
Re: motor knocking
It has had 20 lbs for the last 2 years. What will happen when the riod lets go?
01-24-2008, 10:11 AM | #4 |
Robert Olson Transport
Re: motor knocking
dont bet on it making spring... the bears have a better chance at the superbowl this year
01-24-2008, 10:17 AM | #5 |
Re: motor knocking
At 20 lbs it can handle 2000 rpm if everything inside the engine is right. since you have a knock no telling. If it is a rod and it lets go it will most likely throw it through the side of the block or the oil pan. The engine will be toast. Where is the knock coming from? does it sound like a rod, or could it be something else?
01-24-2008, 10:20 AM | #6 |
Re: motor knocking
I spun a rod bearing before on a car and it sounded like that but now its louder. Its definatly on the bottom end
01-24-2008, 12:10 PM | #7 |
Re: motor knocking
Call the undertaker. It is either dead, or soon will be. If you are serious about scraping the truck then drive it only in areas you won't mind oil being spilled. It will spill, and probably sooner instead of later. If you want to keep it around, drop the pan and find out what is wrong.
01-25-2008, 04:08 AM | #8 |
Re: motor knocking
Put some 80w-90 in it. Sorry I couldnt resist.
I can still count my vehicles on two... wait three hands. |
