Old 01-24-2008, 10:27 AM   #1
blazer bill
rear wheel tubs
Hope This Ain`t A Stupid Question But Are Pickup Bed Tubs The Same As Blazer And Whats The Best Sealant To Go On Them When You Bolt Them Down.
blazer bill is offline   Reply With Quote
Old 01-24-2008, 11:10 AM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: rear wheel tubs
Yes, the rear wheel tubs in the box are the same between pickup and Blazer.
The '72 Blazer I took appart didn't appear to have sealant; I'm not sure if the factory put any in.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 01-24-2008, 11:25 AM   #3
71jimmy
71jimmy's Avatar
Re: rear wheel tubs
Yes the factory used something bt. the wheel tubs and floor. It's body sealer, should be able to find it at any body shop supply store.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 01-24-2008, 12:44 PM   #4
BLUE THUNDER
BLUE THUNDER's Avatar
Re: rear wheel tubs
I don't know what the factory used but you can pick up a tube of 3M seam sealer. I work at a body shop and we use the 3M "fast n firm" seam sealer. Just follow the directions. You can prime it, sand it, and paint it. Hopefully this helps. Mario
BLUE THUNDER is offline   Reply With Quote
Old 01-24-2008, 07:41 PM   #5
vtblazer
vtblazer's Avatar
Re: rear wheel tubs
Use grease, keeps the rust away.
vtblazer is offline   Reply With Quote
Old 01-24-2008, 11:32 PM   #6
Huck
Huck's Avatar
Re: rear wheel tubs
Of the 8 or so blazers I've parted out, every one had some type of body sealer between the floor and the quarter to the tub. Don't use house caulking as it doesn't do a good job of preventing moisture build. 3m seam sealer works great from what I've seen.
Huck is offline   Reply With Quote
Old 01-28-2008, 12:33 AM   #7
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Re: rear wheel tubs
Which one looks like the one anyone has used?
http://solutions.3m.com/wps/portal/3...be6DTWTJQPBBgl
I need to re-seal the cab because the sealant at the drip edge is cracked and falling out. Should I use seam sealer or something else?
Thanks!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
