Old 01-24-2008, 01:58 PM   #1
billsbowtie
billsbowtie's Avatar
? about 6cyl flywheel
will the 6 cyl flywheel work on a sb v-8 eng. when changing from a 6 cyl to a sb.thanks in advance for any help.
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 01-25-2008, 12:11 AM   #2
MikeN
MikeN's Avatar
Re: ? about 6cyl flywheel
Yes, the 6-cyl flywheel works just fine on SB V8 conversions. I swapped my 230ci I6 with 3-speed manual to a 350 V8, and you can use the 6-cyl flywheel, bellhousing, clutch, pressure plate, and starter. I think I even used my 6-cyl water pump pulley.
MikeN is online now   Reply With Quote
Old 01-25-2008, 01:15 AM   #3
crazy longhorn
Fabricate till you "puke"
230/250 flywheel works , but a 292 flywheel wont.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-25-2008, 05:35 AM   #4
MikeN
MikeN's Avatar
Good point. Which reminds me, the 230/250 flywheel will work with MOST small blocks, but not a small block 400, which requires a counterweighted flywheel.
Old 01-25-2008, 07:00 AM   #5
crazy longhorn
Yup, & will work with most early Big blocks, cept the 454 crazyL
Old 01-26-2008, 10:13 AM   #6
billsbowtie
thanks guys i thought they would work.
