Old 01-24-2008, 03:59 PM   #1
MisterE72
Keep Your Nose Clean
Shock relocation kit install.
Greetings to all. Does anyone have pics of a shock relocation kit install like the one from ECE? Even pics the finished product will do. Thanks.
MisterE72 is offline   Reply With Quote
Old 01-24-2008, 04:59 PM   #2
jugernot
Life, Be In It.....
jugernot's Avatar
Re: Shock relocation kit install.
Here is a link to my frame with the ECE relocation kit and super track bar kit installed. I hope it helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=165107
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 01-25-2008, 10:56 AM   #3
MisterE72
Did you have to remove the plates where the shocks originally mounted on the trailing arm? Mine are welded on one side.
Old 01-25-2008, 12:10 PM   #4
see ten
WTB this ad
see ten's Avatar
Sounds like you've got an appointment with a grinder coming up.
So...uh... yes. You'll have to remove them.
see ten is offline   Reply With Quote
Old 01-25-2008, 01:59 PM   #5
MisterE72
That really sucks. The trailing arms are already powdercoated.
Old 01-25-2008, 04:41 PM   #6
jugernot
Life, Be In It.....
jugernot's Avatar
I think Mine were just held on by the U bolts. The only thing I remember doing to the trailing arms was removing the old bushings.
As for removing rivets the best way I have heard in use a cut of wheel to cut a groove across the top of the rivet, then use air hammer to knock the rest off.
There is a link to a how to article from ECE, regarding rivet removal. I know it is a different truck, but go to page two.
http://www.earlyclassic.com/tech.asp...Your%20Xmember
