Old 01-24-2008, 11:39 PM   #1
rotgg
power window problem
i have a 91 gmc extended cab and i cant get the pass side power window working i have put a new motor in and it still doesnt work i cant find a fuse for it so i am stuck
rotgg is offline   Reply With Quote
Old 01-25-2008, 06:27 AM   #2
timzrides
timzrides's Avatar
Re: power window problem
i'm no expert but working on the same situation on my 88. i just picked up new switches and they work now. I was told that the switches can go bad. They were $18 at o'riley's. i also replace the 30 amp circuit fuses. they ar about $3. The power windows and locks are protected thru these circuits.
timzrides is offline   Reply With Quote
Old 01-25-2008, 08:56 AM   #3
rotgg
i also picked up one switch gues i should have replaced both and are the 30 amp circuit fuses the big sliver ones in the fuse block
Old 01-25-2008, 09:21 AM   #4
timzrides
timzrides's Avatar
yeh, my power locks didn't work either and tonight i bought my second, now both locks work. you have to have two working switches in at the same time or one will not work
Old 01-25-2008, 09:24 AM   #5
89 crew
test the switch and if that doesn't cure the problem look at the wires going from the cab to the door I have seen them break there from excessive bending.
89 crew is offline   Reply With Quote
Old 01-25-2008, 10:21 AM   #6
rotgg
its odd to me that both switches would go out at the same time
Old 01-25-2008, 10:51 AM   #7
89 crew
I'm not sure about your truck but I have seen switches wired so if the driver door switch looses contact it kills the other. I would take a volt meter and check the driver door switch first. If there is no power there it is fuse or broken wire. If there is power coming in to the switch it probably won't be coming out.
Old 01-25-2008, 11:21 AM   #8
rotgg
ok i will try that and are the fuses the big silver metal ones
Old 01-25-2008, 11:48 AM   #9
rotgg
is this the fuse
Old 01-25-2008, 01:49 PM   #10
89 crew
That is a relay. It isn't likely for it to be bad and I don't know for sure which fuse does the windows. That is why I would check for power at the switch.
Old 01-26-2008, 07:17 AM   #11
rotgg
it was switches had to replace both
