It followed me home?
lowerd truck/ shock length
I'm going to order some shocks for my blazer and and I'm really not sure what length I need. It's lowered 5-6" in front with springs and lca's, do the lca's make the lenght I need to order closer to stock height? Sorry if thats a dumb question but I want to make sure I get the right parts.
Adam
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 01-25-2008 at 05:08 AM. |
Re: lowerd truck/ shock length
nobody knows? or dumb question?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
I always re mount my stock shocks[back closer to the stock length ] and replace with stiffer ones.Always seemed to work ok for me and a lot cheeper to.
#4 | |
The lca's will still affect the overall length of the shock requirements since the distance between the upper mount & lower mount will be closer vs. stock. If the shock measurements are too short vs. the distance between the shock mounts, you'll need shorter 'drop' shocks; shorter shocks for a different application; or you could relocate the shock mounts (whichever is easiest for you). To determine what length you need, use the measurement of actual distance between the shock mounts when sitting @ ride height. You'll want this measurement to equal the middle of the new shocks travel length (or get as close to the middle as possible). Average suspension travel is 2~3" compression/extension from that middle length. For example, if the ride height measurement is 10" between the mounts, add 2.5" for extension & subtract 2.5" for compression = 10 mid length, 7.5" compressed, 12.5 extended. Look for a shock that's close to your calculated numbers.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-26-2008 at 04:00 AM. |
Follow this link to a thread on another message board that has a chart listing Monroe shocks by end type and length. Measure your truck at ride height like SCOTI suggests above, and then use the chart to find Monroe shocks for your application that you can get at NAPA.
Hope this helps, Ed Last edited by burger; 01-26-2008 at 05:24 AM. |
great, thanks for the info guys. The info in that last link is great!
