Old 01-25-2008, 10:27 AM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
WTB - 2" Rear Lowering Blocks and U-Bolts for Coil Axle
looking for a 2" lowering block and u-bolt set up for a coil spring rear end that someone is not utilizing.
Thanks!!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 01-25-2008, 02:53 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: WTB - 2" Rear Lowering Blocks and U-Bolts for Coil Axle
Doug,
If you can't come up with any you might try these folks. They are in Olathe, KS
http://www.generalspringkc.com/index...parent=32&pg=1
They should have what you want. (just type "blocks" into the search box and scroll down)
I just cut a couple of pieces of 2"x2"-1/4" wall tubing for mine, then had the spring company bend up new "U" bolts 2" longer... Worked great.
LockDoc
Leon
Old 01-25-2008, 03:01 PM   #3
Blue_71
Bloo
Blue_71's Avatar
i think i have a set of blocks, ill check tomarow and let you know. i dont think i have the u-bolts to go with them though
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 01-25-2008, 10:04 PM   #4
tcb-1
tcb-1's Avatar
pm me if you still have the blocks only.
70GMCer,
I saw those blocks. Looks like he just made them out of .50" rect stock. That may be an option!!
Doug
Old 01-25-2008, 09:11 PM   #5
70GMCer
70GMCer's Avatar
Found this today.......
http://cgi.ebay.com/ebaymotors/67-72...spagenameZWDVW
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-25-2008, 10:17 PM   #6
jkade
jkade's Avatar
Made mine out of some 2x6 tubing and work great.
These boys have the u bolts http://www.stengelbros.com/U-boltKits.htm
jkade is offline   Reply With Quote
Old 01-26-2008, 09:13 AM   #7
Blue_71
Bloo
Blue_71's Avatar
heres the pics, they are 3" though. they could extremely easily be cut down. i managed to find one of the u-bolts, but after finding it i didnt bother finding the other... those suckers are thin! i ran these blocks in the rear of my k20 as lift blocks, but they were listed as lift/lowering blocks. they are the tapered kind to fix your pinion angle
Old 01-26-2008, 10:08 AM   #8
tcb-1
tcb-1's Avatar
hummmm, I would have to drill two 1" holes through them right away, unless they fit between the 4.5" center to center u-bolt. I'd really like to stay with 2" drop, but thanks for thinking about me!!
Doug
