Hey guys,
Anyone know how to remove the door glass from Blazer doors? My real problem is freeing the regulator arms from the channel on the bottom of the glass. I unbolted the regulator to try and slide the rollers along to the holes in the channel/track -- but the post on which the handle attaches gets hung up on the hole in the inner door skin. Anyone have any advice? |
![]() Join Date: Dec 1999
did you pull the vent wondow,or loosen up the regulator.
1. remove rear track
2. slide glass back as far as will go 3. remove vent wing assembly 4. make sure glass is rolled all way down 5. slide glass fore and aft till rollers fall out of glass track, use flashlight, youll see notches on face of track towards you towards inside of cab, 6.pull glass out of door 7. youre done, go party |
Thanks Fast, sucker popped right out once I knew the right sequence!
