01-25-2008, 10:52 PM | #1 |
Manifold and vaccum plumbing
are there any pictures someone could post,,,, or a diagram of the manifold plumbing/vaccuum and breather stuff????
01-27-2008, 12:35 AM | #2 |
Re: Manifold and vaccum plumbing
ttt ANYONE?????
01-27-2008, 01:15 AM | #3 |
Maybe this'll help. This is a bare bones vacuum set up.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
01-27-2008, 02:08 AM | #4 |
looks about right..... thanks.......ported vaccuum for advance?? meaning above the throttle plates?
01-27-2008, 07:20 AM | #5 |
Only if you want. Some of us use manifold vacuum .
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
01-28-2008, 04:10 AM | #6 |
now the engine guru who set me up with my 383 stuff says to block off the vaccuum advance on the MSD distributor... I will see
01-28-2008, 04:29 AM | #7 |
If it's a street machine and you want good mileage,you'll want the added advance that the vac adv provides during cruise/light throttle.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
01-28-2008, 12:07 PM | #8 |
okay,, so how should i set my timing up to get the 34* total??? and run the advance from vaccuum... I agree with you cause the guys that did this motor are racing heads.
01-28-2008, 12:52 PM | #9 |
The 34 total doesn't include vacuum advance.That(total advance) is what you get with initial (say,10 degrees) plus max centrifugal advance (perhaps 24 degrees). 10+24 would be 34 total advance at high engine RPMs.They sometime specify that you plug off the vacuum line while checking these figures.
BUT for every-day driving which includes part throttle and cruise conditions,the engine can take much more advance and will reward you with better performance and much better economy.Thus the Vac Advance which is only a factor during PART throttle. Think about it this way; when you are cruising along at 1/8 throttle,only a small amount of air/fuel is entering the cylinders and so the "compression ratio" is very low,maybe 4-1 or something.Therefore if you start the spark earlier,the slow-burning,low compression charge will produce it's power at the optimal point in the cycle.
