Old 01-26-2008, 12:04 AM   #1
MrGoodpliers
MrGoodpliers's Avatar
9 inch rally wheels?
Does anyone know of a source for 9 inch 5 lug truck rallys? All I can find are 8s and 10s. Basically I want to run 8s on the front and have the rear wheels fill out the wheelwells the same amount. (need 1 inch more FRONTSPACE) Are there any manufacturers who make 10s that would fit the bill?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 01-26-2008, 12:19 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 9 inch rally wheels?
I think you mean.....
Are there any manufacturers who make 9s that would fit the bill?
I don't know of anyone who makes 9" wheels....
LockDoc
Leon
Old 01-26-2008, 01:14 AM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
This should be a fairly straightforward process- I'd check with any of the links below for pricing. There may be others, but this is what I found in a quick Google search.
http://www.weldcraftwheels.com/
http://www.stocktonwheel.com/wheel_widening.htm
http://www.internetalternatives.com/wshoppe/wwiden.htm
http://www.vikingwheel.com/
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 01-26-2008, 07:04 AM   #4
MrGoodpliers
I would prefer a 9 inch wheel if I could find it, but I would use a 10 if it has 1 inch more frontspace than a stock 8 inch wheel.
Old 01-26-2008, 07:34 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Stockton Wheel can make you a 10 with any backspacing you want. Just give them a call. Since a stock 15x8 truck ralley has a 4" BS,... just order a 15x10 with a 5" BS. This will bring the wheel "out" 1". I have used them in the past,... just expect to "pay" for their services!
Keith
Convert to disc brakes.
Old 01-26-2008, 10:17 AM   #6
crazy longhorn
Fabricate till you "puke"
http://store.summitracing.com/partde...5&autoview=sku
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-29-2011, 07:00 PM   #7
tples k5
I was thinking the same thing. I have 15x8 all around with 32x11.50 tires. Brothers sells a 15x10 inch rim. Do you think by putting a 10 inch wheel in the rear to fill the wheel well space would look to weird when keeping 8 inch wheels in front ?
tples k5 is offline   Reply With Quote
Old 05-29-2011, 07:47 PM   #8
Grimpala
Grimpala's Avatar
Not with the right backspacing it wouldn't.
Grimpala is offline   Reply With Quote
