Old 01-26-2008, 01:09 AM   #1
dan42
dan42's Avatar
Power steerin pump disassembly
Without starting on taking this apart yet, do I need a special tool to pull the pully off? Or can I just take it to the local bearing place, and they'll take it off for me ?? I want to replace the pump with a new one. Also, does anyone know if the lower bearings on the seering shaft are pressed on or not? It seems like it. Mine won't budge. (Lower picture.)
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 01-26-2008, 01:56 AM   #2
Luvlegs
Luvlegs's Avatar
Re: Power steerin pump disassembly
I can't tell from your pic but on my pump, the center hub was a nut you can take off. You might have a pressed on one, I can't tell, if so, it'll come off with a pulley puller (easy to make one if you don't already have one). Can't speak to the shaft issue
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-26-2008, 02:16 AM   #3
HomerJ
HomerJ's Avatar
Your pulley is pressed on, so you will need a power steering pulley removing tool (or you can fab one up, if so inclined).
The carrier bearing on your driveshaft is pressed on, as well. It usually takes either a hydraulic press or a lot of persistence and a BFH to get them off.
Hope this helps,
HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73
67 Chevelle SS Clone 454/TH400/3.73
HomerJ is offline   Reply With Quote
Old 01-26-2008, 02:16 AM   #4
cdowns
cdowns's Avatar
yes theres a special puller for some power steering pulleys
Old 01-26-2008, 03:45 AM   #5
dan42
dan42's Avatar
Thanks guys.
Philippians 4: 6-7
