Insert Title Here
Anyone ever 3M there upper/lower trim on?
id like to get the upper and lower trim, but i didnt want to mess with drilling holes, and working with all the brackets and clips and stuff... anyone ever 3M them on like they do on new trucks?
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
![]() Join Date: Apr 2005
Re: Anyone ever 3M there upper/lower trim on?
Mar-k sells a kit to do exactly what you are talking about, www.mar-k.com
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Insert Title Here
Man, I thought I came up with something good... I am not seeing the kit on there site... is it just tape? I can get that anywhere
Insert Title Here
Nevermind, i see the kit is with the trim itself... they only list as 71-72.. is there a difference between those and the 69-70? why different numbers
To The Levy
I would think that with our type of trim, (heavier than the newer stuff) it would shift in the heat, the glue that is on the tape would get soft and lose its contact , that wouldnt be too terrible to fix, no real big deal if it did, I suppose, reapply or even then go for the hole drilling method... I can imagine some people on here would like to try trim, but arent sure if they would like , but if they drill holes, well I would guess thats for good, or until the welder and paint came out to fix the holes, with tape, I guess all you need is a little goof off to remove the glue smudges if you dont want the trim. good point, I hope you find some good stuff.
Insert Title Here
The trim itself is actually pretty light, only thing is its not really flat on the underside.. maybe ill just have some strip painted on it or something
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Yup...it works great.
Had all the trim on like this 5 years now. It's never come loose or even started to pull away. ![]() ![]() ![]() ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Self-proclaimed LED man
I 3M'ed my abs plastic kick panel speaker enclosures on...does that count? Not sure how that would hold up to the elements though. I doubt it would hold up. JMO.
Justin
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
Insert Title Here
awesome, thanks for the pics... you used only tape right? no clips at all
Most new car trim and badges are just 3M taped on. I debadged and removed the side mouldings on my late model charger and it was just taped on........taped on really well but taped on none the less. It took about 2 hours with a heat gun and 3 bottles of Goo-gone to get that crap off. I don't see many people with newer cars having their trim peices falling off. I would give it a try and if it sucks or falls off get out the goo-gone.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
![]() Join Date: Dec 2006
I just bought the trim for my '69 that got sideswiped and they sold me plastic clips that hook up like regular molding fasteners,but you put tape on the mounting surfaces.Haven't tried them out yet tho.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
3M two sided tape is the only way to go imho.
#13 |
I have a radical idea!
LMC sells a kit that plastic clips with two sided tape on them. I used it one of the bed pieces on my truck and it worked great.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#14 | |
I welded up all those clip holes before I repainted. Do it,it's awsome stuff.
