86 C10
caliper on drop spindle wont fit?
I need help the freaking caliper does not what to go in i've tried everything i even took the rotor off to see if it was the rotor but still wont fit the hard brake line is hitting the spindle. The spindles are DJM and the calipers are stock.
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() Last edited by baggedcten; 01-26-2008 at 07:27 AM. Reason: spelled spindles wrong |
Re: caliper on drop spindle wont fit?
did you check to see if you had the 1" or 1-1/4" inch brake rotors before you bought the spindles?
Just asking... Can you post pics?
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
86 C10
yea i have the right rotor size is just the caliper wont fit on it it looks like the brake line is hitting the spindle by the upper ball joint thing i dont have my came with me but thats whats happining. I'm going to try to search if it happened to anyone else.
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
Happy to be here
![]() Join Date: Mar 2000
Is it posible you swapped sides with the calipers?
86 C10
all right guys i did a search on here and found out others had the same problem
67-72 parts collector,…
![]() Join Date: Nov 2002
Tweak the steel part of the brake line. I have to do that every time. I don't know why the manufacturer of the spindle doesn't put that in their instructions.
ah, I was confused a little. I had that same problem, a little bendy bendy, all fixed.
Glad it worked out.
1972 Chevrolet SWB
pictures may help
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
86 C10
yea i bent the hard part of the brake line and it work yea
Aside from lookin goofy and riding wierd, it may track a lil off, but it shouldn't hurt any pieces.
86 C10
i just have to add a little more air pressure to one side so it could look even because when i lift it one side looks lower but yea i test drove it around the block and it was alright.
Don't forget to get it aligned when you are done.
#13 |
Active Member
![]() Join Date: Oct 2006
