Old 10-19-2002, 01:25 PM   #1
blue_69
someday
blue_69's Avatar
i want to conver my blazer to 2x?????
I was wondering what my options are to convert my blazer to 2 wheel drive. I would like to go with bags and a stock trailing arm setup but i'm not sure if it can be done. Thoughts and sugestions are appreciated.
jason
Click Here to search ebay for all 67-72 parts
My 72 CST blazer build
72 CST Blazer 4x4
67 2wd swb ( project onion crate )
86 4x4 lwb plow truck
40 x 60 foot barn to work on all this stuff
blue_69 is offline   Reply With Quote
Old 10-19-2002, 01:58 PM   #2
6772king
6772king's Avatar
the two wheel that i have i made from a 4x4 and wanted to do the same thing in the rear but the frame on a 2wd bows out when it get's to the coil sping crossmember if you used bag's and changed the angle of the trailing arm's to match the 4x4 frame you could do but you cant bolt in the factory set up and go. I just took a few of the 4x4 leaves out and got just a little rake but the were allready saging.
6772king is offline   Reply With Quote
Old 10-19-2002, 04:53 PM   #3
blazer boy
hey i've done this to my 69 blazer and if you will pm me then i can give you exact specs on everything i used
blazer boy is offline   Reply With Quote
