Old 01-26-2008, 10:57 AM   #1
gene_champ
heater hose quick connector leaking?
I noticed the quick connector for the heater hose, on the intake monifold, was seeping a little. i went to napa and got a new one. when i pluged the metal end of the hose it, it fit real loose. i don't see how it will hold, even before there is pressure.
is there a better way to do this, or should i just get a hose barb fitting and some hose clamps. then i will know it is tight.
1949 chevy 3100, 5 window
1992 chevy k1500, extended cab, short box 5.7l
1996 chevy k1500, extended cab, long box 5.7l
2001 chevy impala ls 3.8l
1965 honda s90
gene_champ is offline   Reply With Quote
Old 01-26-2008, 11:23 AM   #2
ChevyTech
Re: heater hose quick connector leaking?
The quick connect fittings are a common problem.
There are stainless steel quick connect fittings made, but I don’t know where they can be purchased.
You did good to get the old connector out without breaking it off in the manifold which happens often.
Some people do just as you suggested – replace the quick connector with a fitting that the hose can connect directly to.
The hose can wiggle around a bit with the connector still able to seal.
Old 01-26-2008, 11:27 AM   #3
edman87
junk collector
The 1 on my tahoe will leak if you pull on the hose, but seals up fine otherwise. Just screwing in a pipe fitting is a common solution.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 01-29-2008, 05:58 PM   #4
get me on the road
No Matter What.
get me on the road's Avatar
This maybe a little late gene, but if you still need one you can have this one (see pic). Just pm me with your address and I'll ship it out, dont worry about the shipping charges. When I was a mechanic we went through alot of these, so I have a few in my box.
Currently own:
89 Chevy Silverado
Previously Owned:Starting with my first vehicle
86 Mercury Cougar /89 Olds 88 /88 Chevy S-10 /84 Pontiac Firebird(I miss it) /91 Chevy S-10
get me on the road is offline   Reply With Quote
Old 02-01-2008, 01:00 AM   #5
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
There is an easy fix to this problem. You can go to your local advance and get a 1/2" npt heater nipple and run a regular heater hose to the heater core. There is a restrickter in the factory hose and some say that if you do it the way that I suggested that it will blow out you heater core but I have not yet had any problems with mine. 7 bucks is all that this will cost you.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 02-02-2008, 11:04 AM   #6
gene_champ
Smile Re: heater hose quick connector leaking?
thanks for the helpful advise. it was like 10 below 0 outside, and i didn't want to get stranded on the road because of this el cheapo patented connector. i don't think ford would even claim this as a better idea.
i ended up putting another small o ring on, so it fits halfway tight. it didn't leak, so i think i will leave it alone. good to have that fixed without any major headache.
1965 honda s90
Old 02-04-2008, 11:44 AM   #7
Sadsack
Sadsack's Avatar
Any GM dealership has the new replacement steel ones...the original ones were made of a semi porous metal that over the yrs absorbs the coolant and swells..usually resulting in the threads breaking in the manifold when you try to remove it...the new ones work perfect...and yes the do feel really loose on some but usually no probs...
Sadsack is offline   Reply With Quote
Old 02-11-2008, 07:44 PM   #8
HtownPapiJc
my CheVy TrUcks
HtownPapiJc's Avatar
It probably didnt help if that GM dexcool was in your system either.....they finally settled on that lawsuit against GM not too along ago for repairs on some models. Ive had to change that same connector out along with the intake gasket. And didnt bother putting that GM stuff back in. When with the green stuff so its noticable in the oil if that gasket fails again.
J.Garcia
1998 Chevy Silverado V-8 305/5.0 liter
2005 Pontiac Grandam V-6/3.4 liter
1989 Chevy 1500 Suburban (Aug/2007 Project)
HtownPapiJc is offline   Reply With Quote
