Old 05-03-2002, 05:34 PM   #1
mark25
Post What Cam Is In Your 383 Stroker????
Decided to quit piddle farting around with my 355, and make it into a 383 torque monster. what cam are ya all running, like/dislike??? i am running a 3.73 limited slip diferential and a built TH350 with a B&M Holeshot 12" 1900-2100 stall. would like a cam that had a power range of approx. 1500-6500 RPM range.
i have the Edelbrock Performer RPM and Performer 750 carb. i wonder how the performer rpm #7102 cam kit would work in a 383???
'72 C-10 Cheyenne Super, 402/TH400, Bucket Seats, tilt, tach, AM/FM & shoulder harnesses and a ground up restoration
mark25 is offline   Reply With Quote
Old 05-03-2002, 07:53 PM   #2
superchevy
Got big-block?
superchevy's Avatar
Post
Here's a list from a previous post. Don't be fooled by the "nitrous" cam specs - I don't run NOS, the cam was recommended by the engine builder to increase exhaust flow out of the heads while providing a good idle and vacuum.
I have a 388 ( 60 over 350 ). 4-bolt block, Scat crank, Scat rods, KB Hypereutectics at 9.7:1, Lunati nitrous cam 225/235 dur at 50, 477/507 lift. TrickFlow heads, Edelbrock Performer RPM, Edelbrock 750 carb.
Built by strokermotor.com here in Dallas.
Dyno'ed at 430hp and 470lbft torque.
Idles great at 800 rpm and hauls a@# when you hammer it.
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 05-03-2002, 10:21 PM   #3
69 longhorn
Post
I have an Xe 268 comp cam. .477/.480 lift,224/230 duration@ .050. I have an 11" TCI verter(2400-2800 advertised stall),& 4.10 coggs in the 12 bolt......an all around good combo with edelbrock rpm heads/intake/carb,with good street manners........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-03-2002, 10:47 PM   #4
Beast388
Suburbans RULE!
Beast388's Avatar
Talking
See signature below.....
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, Scat crank, H-beam steel rods, KB Pistons, Speed-Pro Moly Rings, Clevite bearings, Speed-Pro High Volume oil-pump, Comp Cams 254H 4X4 Xtreme cam, SR Torquer 2.02/1.60 heads, Comp springs, Trick Flow pushrods, Comp Roller Rockers, Edelbrock Performer RPM intake, 3310 750cfm Holley, Summit HEI, MSD 6AL, Built TH350 Transcat Supper II shift kit 2000 RPM Stall, 4" Rough Country Lift....etc.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 05-04-2002, 10:24 PM   #5
UNCLEBOB
Post
I have a lunati 235 dur 507 lift rpm heads manifold 10.4 commpression 4.57 gears first time out this year ran 13.36. Hope to improve with tuning.
68 lwb 383 solid roller,250dur, 582lift, afr 210s, 10.8 comp. edel.rpm, 750vs,1 3/4 headers turbo 400, 3500 stall,ford 9 inch 3.89 gears
UNCLEBOB is offline   Reply With Quote
Old 05-05-2002, 12:01 AM   #6
Stroker
Post
mark25 the 5,000 rpm power band might be a bit optimistic. A 383 will need a very good head and a fairly big cam to pull hard all the way to 6,500 rpm. By the time you get that kind of air capacity you'll be somewhat soggy on the bottom end and will need about a 3000 stall. The good news is 383s can make near 500hp below 6,000rpm. Check out the 383 chevy dynos at: www.airflowresearch.com/
[This message has been edited by Stroker (edited May 05, 2002).]
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
